How do I export pictures for multiple design points?
Pierre Thieffry
I am running a simulation for which I create figures for various results. I want to export them for each design point. How can I do this?
  • Pierre Thieffry
    Here's a sample code to use in a Python Code object. For this to work, you will have to use version 23.1 and above as picture export in batch mode did not work in earlier versions.
    Small bonus: you'll see how to retrieve the design point number and the user_files folder without the need for executing a script at project page level.
      Called after post processing.
      Keyword Arguments :
        solution -- Solution
      figures=ExtAPI.DataModel.GetObjectsByType(DataModelObjectCategory.Figure)
      cmd = 'returnValue(GetUserFilesDirectory())'
      wd=this.Parent.Parent.WorkingDir
      dp=wd.split('\\')[-4]
      user_dir=os.path.join(wd,'..\\..\\..\\user_files')
      for fig in figures:
        ExtAPI.DataModel.Tree.Activate(fig)
        filename=user_dir+'\\'+'Figure - '+fig.Parent.Name+'_'+dp+'.jpg'
        ExtAPI.Graphics.ExportImage(filename)
  • Dima
    Dima Member Posts: 1
    Hello @Pierre Thieffry ,
    thank you for the post, it is really helpful!
    I am trying to do some modifications on the legend text, to increase it.
    I've tried something like this based on the documentation which I found on the web, but it is not working:
    ExtAPI.Graphics.ExportImage(filename,  GraphicsImageExportFormat('png'), GraphicsImageExportSettings.FontMagnification(1.3))
    Can you help me please with this ?
  • M
    M Member, Employee Posts: 256
    edited January 2024
    Figures in this example mean static generated images and not the dynamic Ansys plots. .AddFigure() will add the figure below any selected result.
    I have an adaptation that will generate the image if it doesn't already exist and write that image to file:
        Keyword Arguments :
        import wbjn
        dpn = wbjn.ExecuteCommand(ExtAPI,"returnValue(a+Parameters.GetActiveDesignPoint().Name)",a="DP")
        user_dir = wbjn.ExecuteCommand(ExtAPI,"returnValue(GetUserFilesDirectory())")
        results = ExtAPI.DataModel.GetObjectsByType(DataModelObjectCategory.Result)
        for result in results:
            ExtAPI.Log.WriteMessage('bob')
            children = result.Children
            if not any(i for i in children if 'Figure' in i.ToString()):
                children = result.AddFigure()
            elif 'Figure' in children[0].ToString():
                children = children[0]
            children.Activate()
            filename = os.path.join(user_dir,'Figure - '+children.Parent.Name+'_'+dpn+'.jpg' )
            ExtAPI.Log.WriteMessage(filename)
            ExtAPI.Graphics.ExportImage(filename,GraphicsImageExportFormat.JPG)
