Code:
dpf.__version__
mesh_attr_op = dpf.operators.mesh.mesh_get_attribute()
'0.8.1'
Returns:
'0.8.1'
KeyError Traceback (most recent call last)
Cell In[8], line 1
----> 1 mesh_attr_op = dpf.operators.mesh.mesh_get_attribute()
2 print(mesh_attr_op.inputs)
3 print(mesh_attr_op.outputs)
File c:\users\e092220\.venv\3.9.6\pyansys-latest\lib\site-packages\ansys\dpf\core\operators\mesh\mesh_get_attribute.py:74, in mesh_get_attribute.__init__(self, abstract_meshed_region, property_name, property_identifier, config, server)
66 def __init__(
67 self,
68 abstract_meshed_region=None,
72 server=None,
73 ):
---> 74 super().__init__(name="mesh::get_attribute", config=config, server=server)
75 self._inputs = InputsMeshGetAttribute(self)
76 self._outputs = OutputsMeshGetAttribute(self)
File c:\users\e092220\.venv\3.9.6\pyansys-latest\lib\site-packages\ansys\dpf\core\dpf_operator.py:120, in Operator.__init__(self, name, config, server)
117 self._internal_obj = self._api.operator_new(self.name)
119 if self._internal_obj is None:
--> 120 raise KeyError(
121 f"The operator {self.name} doesn't exist in the registry. "
122 f"Check its spelling in the documentation or verify its availability "
123 f"in your Context (Entry/Premium) and in your loaded plugins."
124 )
126 self._spec = Specification(operator_name=self.name, server=self._server)
127 # add dynamic inputs
KeyError: "The operator mesh::get_attribute doesn't exist in the registry. Check its spelling in the documentation or verify its availability in your Context (Entry/Premium) and in your loaded plugins."
On Windows, with ANSYS 2022R2 installed. Can you please explain what is going on here?
