Combine mode shapes using Mechanical automation API
Pernelle Marone-Hitz
Member, Moderator, Employee Posts: 899
I've run an eigenvalue buckling analysis and would like to:
- add a mode shape result for all eigen modes
- add a user-defined result that will plot a combined deformation of the mode shapes, with a scale factor
The following code can be adapted. A total deformation result is added for each eigen value, and an identifier is defined on the mode:
Then scaling values are defined. In this example we use a scale value of 10 for the first mode, and 20 for all others.
Finally, a user defined result is inserted with the combination of modes with the scaling values:
The code is:
eigenvalue_buckling_analysis = ExtAPI.DataModel.AnalysisByName('Eigenvalue Buckling') reader = eigenvalue_buckling_analysis.GetResultsData() result_sets = reader.ListTimeFreq solution = eigenvalue_buckling_analysis.Solution result_list = [] for i in range(1, len(result_sets)+1): result = solution.AddTotalDeformation() result.Mode = i result.Identifier = "Mode" + str(i) result_list.append(result.Identifier) scale_value_1 = 10 scale_value_2 = 20 modified_result_list = [str(scale_value_1)+"*%s" % value if i == 0 else str(scale_value_2)+"*%s" % value for i,value in enumerate(result_list)] delimiter = "+" udr_expression = delimiter.join(map(str, modified_result_list)) udr = solution.AddUserDefinedResult() udr.Expression = udr_expression solution.EvaluateAllResults()
The final plot of the combined result:
