How to plot result on cut mesh using PyDPF
Hi
I would like to plot a one side of a volume geometry, for which I have nodal results, and would like to cut the geometry with specific plane.
I have tried the mesh_plan_clip operator but as soon as I use it, the output mesh is cannot really plot the results.
I have tried to create a possible solution with the PyVista and clipping tool, without any success.
Can you please let me know how I can plot it outside of mechanical and still use sections.
or is it a limitation of PyDPF at the moment?
  • kanchan_cadfem
    kanchan_cadfem Member Posts: 21
    Second Anniversary 10 Comments 5 Likes First Answer
    @Ayush Kumar, any comments on this?
    clipping volumes and plotting with PyDPF pr PyVista?
  • Ayush Kumar
    edited May 2023
    @kanchan_cadfem I have never tried with PyVista, but the example below looks promising. You need to convert the DPF data to PyVista format:
    If you are facing issues with mesh_plan_clip please file an issue on GitHub. The operator is supposed to do exactly this.
  • Rajesh Meena
    Rajesh Meena Moderator, Employee Posts: 136
    @kanchan_cadfem @Ayush Kumar
    I just used it with PYDPF. The hack for now is that you need to plot the mesh with field before you use section cut.
    import pyvista
    rFile = "/path_to_rst/file.rst"
    pyvista.set_plot_theme("document")
    pyvista.global_theme.cmap = 'jet'
    my_data_sources = dpf.DataSources(rFile)
    my_data_sources.result_files
    model = dpf.Model(my_data_sources)
    results = model.results
    displacements = results.displacement()
    fields = displacements.outputs.fields_container()
    mesh.plot(fields,off_screen=True)
    normal = (1, 1, 1)
    plane = pyvista.Plane(i_size=30, j_size=30, direction=normal)
    pv_mesh = mesh.grid
    clipped = pv_mesh.clip(normal=normal)
    p = pyvista.Plotter()
    p.add_mesh(clipped, show_edges=True)
    p.show()
