Example of worflow automation: create geometry, model setup, and postprocess
Pernelle Marone-Hitz
Pernelle Marone-Hitz Member, Moderator, Employee Posts: 898
edited June 2023 in 3D Design
Is there an example of workflow automation with geometry creation, model setup and postprocessing?
    edited May 2023
    Below is an example.
    First, we'll create the geometry.
    The script below will work both in SpaceClaim and in Discovery. It:
    • creates a base block and four smaller blocks on the top
    • defines a name for the base block
    • creates four named selections (one for the base block body, one for the smaller blocks bodies, one for the bottom base face and one for the upper faces)
    # Python Script, API Version = V23
    ClearAll()
    # Geometry dimensions
    par_L = MM(50) # length of base block
    par_W = MM(25) # width of base block
    par_H = MM(10) # height of base block
    par_l = MM(20) # length of small block
    par_w = MM(10) # width of small block
    par_h = MM(5) # height of small block
    offset = MM(2.5)
    # Create base block
    base_block = BlockBody.Create(Point.Create(MM(0), MM(0), MM(0)), Point.Create(par_L, par_W, par_H ), ExtrudeType.ForceAdd)
    base_block.CreatedBodies[0].SetName('Base Block Body')
    my_body_selection = Selection.Create(base_block.CreatedBodies[0])
    my_body_selection.CreateAGroup('Base Block NS')
    my_faces_selection = my_body_selection.ConvertToFaces()
    for face in my_faces_selection.Items:
        if face.EvalMid().Point.Z == MM(0):
            Selection.Create(face).CreateAGroup('Base Face NS')
     # Create smaller blocks
    small_block_1 = BlockBody.Create(Point.Create(offset, offset, par_H ), Point.Create( par_L/2 - offset, par_w, par_H + par_h ), ExtrudeType.ForceIndependent)
    small_block_2 = BlockBody.Create(Point.Create(par_L/2 + offset, offset, par_H ), Point.Create(par_L-offset , par_w, par_H + par_h ), ExtrudeType.ForceIndependent)
    small_block_3 = BlockBody.Create(Point.Create(offset, par_W - offset-par_w, par_H ), Point.Create( par_L/2 - offset, par_W - offset , par_H + par_h ), ExtrudeType.ForceIndependent)
    small_block_4 = BlockBody.Create(Point.Create(par_L/2 + offset, par_W - offset-par_w, par_H  ), Point.Create(par_L-offset , par_W - offset, par_H + par_h), ExtrudeType.ForceIndependent)
    my_body_selection = Selection.Create(small_block_1.CreatedBodies[0], small_block_2.CreatedBodies[0], small_block_3.CreatedBodies[0], small_block_4.CreatedBodies[0])
    my_body_selection.CreateAGroup('Small Blocks NS')
    top_face_list = []
        if face.EvalMid().Point.Z == par_H + par_h :
            top_face_list.append(face)
    Selection.Create(top_face_list).CreateAGroup('Top Faces NS')
    In SpaceClaim, the resulting tree can be found in the "Structure" tab, and the named selections in the "Groups" tab:
    In Discovery, the tree is on the top left:
    and the named selections can be found in the "Advanced Selection" menu at the bottom right:
    Then, we'll create the Mechanical model setup and postprocessing.
    For the script to work, it is assumed that two materials have already been added in Engineering Data:
    User: "image.png"
    (these could also be created through scripting). It is also assumed that a Steady State thermal analysis is considered (the code could easily be adapted for other boundary conditions for other types of analyses).
    User: "image.png"
    The script will:
    • add material assignements
    • add boundary conditions based on named selections
    • insert results
    • export these results to a specified folder to extract screenshots of the plots, animations of the plots, and values of the plots
    The Mechanical script is:
    # Retrieve bodies
    all_bodies = ExtAPI.DataModel.Project.Model.Geometry.GetChildren(DataModelObjectCategory.Body,True)
    base_block_body = [body for body in all_bodies if body.Name.Contains('Base')]
    small_block_bodies = [body for body in all_bodies if body.Name.Contains('Solid')]
    # Define material assignation
    material_assignation_steel = ExtAPI.DataModel.Project.Model.Materials.AddMaterialAssignment()
    sel = ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.GeometryEntities)
    sel.Ids = [body.GetGeoBody().Id for body in base_block_body]
    material_assignation_steel.Location = sel
    material_assignation_steel.Material = 'Structural Steel'
    material_assignation_iron = ExtAPI.DataModel.Project.Model.Materials.AddMaterialAssignment()
    sel.Ids = [body.GetGeoBody().Id for body in small_block_bodies]
    material_assignation_iron.Location = sel
    material_assignation_iron.Material = 'Aluminum'
    # Define boundary conditions based on Named Selections
    temp_base = analysis.AddTemperature()
    temp_base.Location = ExtAPI.DataModel.GetObjectsByName("Base Face NS")[0]
    temp_base.Magnitude.Output.SetDiscreteValue(0, Quantity(50, "C"))
    convection = analysis.AddConvection()
    convection.Location = ExtAPI.DataModel.GetObjectsByName("Top Faces NS")[0]
    convection.FilmCoefficient.Output.SetDiscreteValue(0, Quantity(25, "W m^-1 m^-1 C^-1"))
    convection.AmbientTemperature.Output.SetDiscreteValue(0, Quantity(5, "C"))
    # Solve model
    analysis.Solve()
    # Insert results
    solution = ExtAPI.DataModel.Project.Model.Analyses[0].Solution
    temp_plot = solution.AddTemperature()
    temp_plot_on_ns = solution.AddTemperature()
    temp_plot_on_ns.Location = ExtAPI.DataModel.GetObjectsByName("Top Faces NS")[0]
    solution.EvaluateAllResults()
    # Export results
    export_folder = r'D:\Data'
    all_results = solution.GetChildren(DataModelObjectCategory.Result,True)
    for result in all_results:
        export_name = os.path.join(export_folder,result.Name)
        ExtAPI.Graphics.ExportImage(export_name +'.png')
        result.ExportAnimation(export_name + '.avi')
        result.ExportToTextFile(export_name + '.txt')
