How to extract contact reaction forces using DPF from inside mechanical
Vishnu
  • Vishnu
    edited May 2023
    below is a function which does this extraction.
    You need to pass the object name as the argument to this function.
    def get_cont_reaction(contact_obj_name):
        Use like below:    get_cont_reaction("Contact Region")
        first_solution = ExtAPI.DataModel.Project.Model.Analyses[0].Solution
        solver_data = first_solution.SolverData
        contact_object = ExtAPI.DataModel.GetObjectsByName(contact_obj_name)[0]
        contact_object_data = solver_data.GetObjectData(contact_object)
        cont_elem_type_id = contact_object_data.SourceId
        cont_elems = solver_data.ElementIdsByMaterialId(str(cont_elem_type_id))
        import mech_dpf
        #Result Data
        analysis1 = ExtAPI.DataModel.Project.Model.Analyses[0]
        dataSource = dpf.DataSources(analysis1.Solution.ResultFilePath)
        #model
        my_model = dpf.Model(analysis1.Solution.ResultFilePath)
        #my mesh
        my_mesh = my_model.Mesh
        #time scoping
        my_time_scoping = [1]
        #scoping
        my_scoping = dpf.Scoping()
        my_scoping.Location = "Elemental"
        my_scoping.Ids = cont_elems
        CX = dpf.operators.result.mapdl.nmisc(time_scoping=my_time_scoping,mesh=my_mesh,data_sources=dataSource,item_index = 43,mesh_scoping=my_scoping).outputs.fields_container.GetData()[0]
        CY = dpf.operators.result.mapdl.nmisc(time_scoping=my_time_scoping,mesh=my_mesh,data_sources=dataSource,item_index = 44,mesh_scoping=my_scoping).outputs.fields_container.GetData()[0]
        CZ = dpf.operators.result.mapdl.nmisc(time_scoping=my_time_scoping,mesh=my_mesh,data_sources=dataSource,item_index = 45,mesh_scoping=my_scoping).outputs.fields_container.GetData()[0]
        #Release Locked RST
        my_model.ReleaseStreams()
        return [-sum(CX.Data),-sum(CY.Data),-sum(CZ.Data)]
  • Vishnu
    The nmisc result operator is updated in recent releases like below:
    dpf.operators.result.nmisc
  • Harikrushna
    Harikrushna Member Posts: 7
    Name Dropper First Comment First Anniversary
    Error "Error HRESULT E_FAIL has been returned from a call to a COM component."
