When using MotorCAD2023, how can I control Motor-CAD from a remote machine over HTTP. Is there any examples?
I used the "set_server_ip" command, but couldn't launch Motor-CAD from the remote computer.
Hello @xingshang ,
I do not think it is possible to launch remote Motor CAD using script. What you can do is that Launch the Motor CAD manually in remote machine and then connect to it from your local machine.
If you want to launch remote MotorCAD from your machine, then you may want to use wmi (WMI · PyPI) module.
Thanks,
Rajesh
@xingshang @Rajesh Meena @PyMotorCAD-Team
Please share the script on how to connect the remote machine using PyMotorCAD.
