I need to improve waveguide simulation by plotting |s21| and port phase different (pref. in Matlab), setting a customized orientation view with theta, psi, phi=90,90,0, and by using hfss.plot (or in an alternative way) saving different views( isometric, customized, ...) in different files
This is the code I need to improve:
from pyaedt import Hfss
from pyaedt import Desktopd = Desktop(non_graphical=False, new_desktop_session=False, student_version=True)
hfss = Hfss(solution_type="DrivenModal")hfss["a"] = "20mm"hfss["b"] = "10mm"hfss["l"] = "75mm"
#WAVEGUIDE
air=hfss.modeler.create_box(["0","0","0"], ["a","b","l"],"waveguide","vacuum")
hfss.modeler.fit_all()s1=hfss.modeler.create_object_from_face(air.bottom_face_z)
s1.name=’p1’
p1=hfss.create_wave_port_from_sheet(s1,portname="1") s2=hfss.modeler.create_object_from_face(air.top_face_z)
s2.name=’p2’
p2=hfss.create_wave_port_from_sheet(s2,portname="2")
########## Apply a customized Orientation view with theta, psi, phi=90,90,0########
setup = hfss.create_setup("MySetup")
setup.props["Frequency"] = "10GHz"
setup.props["MaximumPasses"] = 20
hfss.create_linear_count_sweep(
setupname=setup.name,
unit="GHz",
freqstart=8,
freqstop=11,
num_of_freq_points=451,
sweepname="sweep",
sweep_type="Interpolating",
interpolation_tol=3,
interpolation_max_solutions=50,
save_fields=False,
########## PLOT |S21| AND PHASE DIFFERENT BETWEEN port 1 and 2 (creating figures in Matlab) #####
#####Using hfss.plot to save figures with different views (trimeric, xy, customized,...)
hfss.analyze_setup("MySetup")
hfss.close_project()
d.release_desktop()
