How to define the imaginary part of a remote force using ACT?
Ayush Kumar
Member, Moderator, Employee Posts: 497
You can convert your Real and Imaginary values into Magnitude and Phase angle. Those two quantities can be applied in the form of a vector load using the following example:
rf = analysis.AddRemoteForce() # Scope the result object to the desired body … Im = 3. Re = 4. resultant = sqrt(Im**2 + Re**2) rf.DefineBy = LoadDefineBy.Vector rf.Magnitude.Output.DiscreteValues = [Quantity("%s [N]" % resultant)] phase = atan(Im / Re) * 180 / pi rf.PhaseAngle.Output.DiscreteValues = [Quantity("%s [deg]" % phase)] # If for example the force is applied in the Global Z-Axis rf.Direction = Vector3D(0, 0, 1)
