Assign thickness values defined in a csv file to surfaces in Spaceclaim?
Erik Kostson
Member, Employee Posts: 52
How can we automatically assign thickness values defined in a csv file to surfaces in Spaceclaim?
Below is a sample code that does that. It is assuming that the pre-existing csv file (file called mythick.csv in D drive) has one column with the surface names in Spaceclaim and one with their thicknesses.
Note: for the below to work we need to have insert selection set to index.
# Python Script, API Version = V22 import csv th=[] names=[] with open('D:\mythick.csv', 'rb') as f: reader = csv.reader(f) for row in reader: th.append(row[1]) names.append(row[0]) allBodies = GetRootPart().GetAllBodies() i=0 for name in names: for body in allBodies: if body.GetName()==name: print(body.GetName()) result = Midsurface.Convert(BodySelection.Create(body), MM(float(th[i]))) i=i+1
