PyDPF version of CYCPHASE
ChrisC
ChrisC Member Posts: 7
edited June 27 in Structures
Is there a PyDPF equivalent of the CYCPHASE command? I looked all through the documentation and examples, and wasn't able to find anything. Can specify a specific phase angle, which is nice. But most stress and life type evaluations happen on CYCPHASE type output.
  • Chris Harrold
    Chris Harrold Member, Administrator, Employee Posts: 90
    10 Comments First Anniversary First Answer Ansys Employee
    admin
    @Ramdane can you take a look at this one
  • Ramdane
    Ramdane Member, Employee Posts: 7
    First Anniversary Ansys Employee Name Dropper First Comment
    @Oscar , is this something you can help on?
  • Oscar
    Oscar Member, Employee Posts: 9
    Ansys Employee First Comment Photogenic
    Hi Chris,
    Please find an example of script running a maximum over cyclic phase for displacements. This procedure could be also used for stresses.
    Please, let me know if you have any further question on this.
    Regards,
    Oscar
    Import modules and set the location of your files
    import numpy as np
    Path = r'YOUR PATH'
    dataSource = dpf.DataSources()
    dataSource = dpf.Model(os.path.join(Path,"file.rst"))
    Variables
    set_number = [1]
    phaseInc = 2
    deg_to_rad = np.pi / 180.
    Get the operator to expand with cyclic option 1 (read cyclic without performing expansion, expansion will be done through cyclic_expansion operator)
    u = dpf.operators.result.displacement()
    u.inputs.time_scoping.connect(set_number)
    u.inputs.data_sources.connect(dataSource)
    u.inputs.bool_rotate_to_global.connect(False)
    u.inputs.read_cyclic.connect(1)
    Get cyclic support and cyclic expansion operators
    cyclicSupport = dpf.operators.metadata.cyclic_support_provider()
    cyclicSupport.inputs.data_sources.connect(dataSource)
    cyc_expansion = dpf.operators.result.cyclic_expansion()
    cyc_expansion.inputs.fields_container.connect(u)
    cyc_expansion.inputs.cyclic_support.connect(cyclicSupport)
    cyc_expansion.connect(18, [0]) #Sector number to expand, here, just one sector is expanded here, however, if results are expected to change per sector, all sectors should be expanded (e.g. displacement in global CS)
    Get maximum over cyclic phase
    min_max_op = dpf.operators.min_max.min_max_over_time_by_entity(cyc_expansion.outputs.fields_container.get_data())
    for i in range(0, 360, phaseInc):
    angle = i * deg_to_rad
    cyc_expansion.connect(19, angle)
    min_max_op.run()
    meshProvider = dpf.operators.mesh.mesh_provider()
    meshProvider.inputs.data_sources.connect(dataSource)
    meshProvider.inputs.read_cyclic.connect(2)
    meshProvider.connect(18, [0])
    mesh = meshProvider.outputs.mesh()
    mesh.plot(min_max_op.outputs.max.get_data()[0])
