Volume of a body in Mechanical
Indrajit
Indrajit Member Posts: 5
I am trying to get the volume of individual bodies in a Geometry assembly.
ExtAPI.DataModel.Project.Model.Geometry.Volume gave me the total volume of the model.
How should I get the volume of individual ones
Thanks,
Indrajit
  • Indrajit
    The following works
    entity = ExtAPI.DataModel.GeoData.GeoEntityById(sel.Ids[i])
    Volume = entity.Volume
    Thanks!
    Pernelle Marone-Hitz Member, Moderator, Employee Posts: 900
    Hi @Indrajit , happy to see you on the forum and thanks for sharing your knowledge! There's two ways you can retrieve that information.
    As it is some information that is shown in the details view of the "tree geometry" for each body:
    You can use the Model API to get that info:
    bodies = Model.Geometry.GetChildren(DataModelObjectCategory.Body, True)
    for body in bodies:
        print('Body volume is: ' + str(body.Volume))
    This returns:
    Another method is to use GeoData to retrieve that information:
    for body in bodies:
        geobody = body.GetGeoBody()
        print('Body volume is: ' + str(geobody.Volume))
    This returns:
    For an explanation of the difference between a body as seen from the Mechanical tree and as seen from Geodata, please refer to this post:
    https://discuss.ansys.com/discussion/2288/whats-the-difference-between-tree-geometry-and-geodata-in-mechanical-api/p1?new=1
  • Indrajit
    Hi Pernelle,
    Thanks a lot.
    Lots of options to select from.
    Is there a Python command manual for Spaceclaim?
    Hi @Indrajit , sorry for the late answer, I am back in the office just today.
    You can find a Developers Guide in the SpaceClaim installation files. If you're using a standard installation path, for 2023R1 this would be: C:\Program Files\ANSYS Inc\v231\scdm\SpaceClaim.Api.V23.
  • M
    M Member, Employee Posts: 256
    edited March 2024
    If you wanted to write the body data to file, you could use this script:
    save_directory = 'D:\\temp'
    save_file = 'body_data.csv'
    data = [] # result will be stored in the parameter 'data'
    for body in bodies:
        name = body.Name
        volume = body.Volume.Value #.Value for numeric results without units, !always be sure of your units
        mass = body.Mass.Value
        material = body.Material # Name of material
        data.append([name,material,volume,mass])
    with open(os.path.join(save_directory,save_file),'w') as f: # 'w' is to write to file
        for line in data:
            for data_point in line:
                f.write(str(data_point) + ',')
            f.write('\n')
