How to extract information aboout converged or unconverged solution
Massimo
Massimo Member Posts: 4
I need to extract by means of a Python script the information if a solution is converged or not (i.e.: how to read in the solution object the value for Substep, something like "if Substep equal 999999 not converged...")
Thank you very much
    Are you only wanting to know if the solution converged or not, or do you need information about which step and substep the solution diverged?
    If you are only looking for if the solution completed or not you can look at the Solution object ObjectState property
  • Massimo
    Hello Mike
    Thank you for your reply; I need to extarct which step and substep the simulation diverged
    Best
  • Massimo
    Hello Mike
    Just to clarify my goal; I'm currrently read results from result file and by means of the following script I'm setting the final substep of the final step; but I'm assuming that the final result set is valid (converged); if not (how to know?) I need to read the last but one result
    Thank you very much for your help
    Massimo
    reader = ExtAPI.DataModel.Project.Model.Analyses[0].GetResultsData()
    result_sets = reader.ListTimeFreq
    lastRes=len(result_sets)-1
    reader.CurrentTimeFreq = result_sets[lastRes] # Set last result set
  • Massimo
    Hello Rajesh,
    thank you very much for your reply, this will be very helpful for my purpose and it solved my issue
    Best regards
