It has come to my attention that several users have issues editing the legend in the Mechanical UI due to a graphical defect with certain NVIDIA GPUs.
How can I create a python button in Mechanical that allows me to edit the upper/lower bounds?
Following snippet can be imported into the Button Editor to edit the legend
Triggering the button will prompt the user to fill in the upper/lower bounds of the contour.
The code itself is pasted below.
import clr clr.AddReference("Ans.Utilities") clr.AddReference('Ans.UI.Toolkit') clr.AddReference('Ans.UI.Toolkit.Base') import Ansys.UI.Toolkit import Ansys.UI.Toolkit.Base def ChangeContours(): try: example = ContourGUI() example.Run() except: ExtAPI.Log.WriteError("Exception in ChangeContours()") def GetMinMax(): try: legendSettings = Ansys.Mechanical.Graphics.Tools.CurrentLegendSettings() noBands = legendSettings.NumberOfBands minVal = legendSettings.GetLowerBound(1).Value maxVal = legendSettings.GetLowerBound(noBands-1).Value return minVal, maxVal except: ExtAPI.Log.WriteError("Exception in GetMinMax()") class WindowUI(Ansys.UI.Toolkit.Window): aLabel = None aButton = None aTextBox = None mainPanel = None def __init__(self): self.Location = Ansys.UI.Toolkit.Drawing.Point(100,100) self.Text = 'Contour editor' self.Size = Ansys.UI.Toolkit.Drawing.Size(250,150) self.StatusBar.Visible = False self.__BuildUI() #this will be defined later self.BeforeClose += Ansys.UI.Toolkit.WindowCloseEventDelegate(self.Window_Close) def __BuildUI(self): res_unit = Tree.FirstActiveObject.Maximum.Unit self.mainPanel = Ansys.UI.Toolkit.TableLayoutPanel() self.Add(self.mainPanel) self.mainPanel.Columns.Add(Ansys.UI.Toolkit.TableLayoutSizeType.Percent, 100) self.mainPanel.Rows.Add(Ansys.UI.Toolkit.TableLayoutSizeType.Percent, 33) self.mainPanel.Rows.Add(Ansys.UI.Toolkit.TableLayoutSizeType.Percent, 34) self.mainPanel.Rows.Add(Ansys.UI.Toolkit.TableLayoutSizeType.Percent, 33) omin,omax = GetMinMax() label1 = 'UPPER - Max Value [' + res_unit + ']' self.aLabel = Ansys.UI.Toolkit.Label(label1) self.mainPanel.Controls.Add(self.aLabel, 0, 0) self.aTextBox = Ansys.UI.Toolkit.TextBox() self.aTextBox.Text = omax.ToString() self.mainPanel.Controls.Add(self.aTextBox, 1, 0) label1 = 'LOWER Min Value [' + res_unit + ']' self.bLabel = Ansys.UI.Toolkit.Label(label1) self.mainPanel.Controls.Add(self.bLabel, 2, 0) self.bTextBox = Ansys.UI.Toolkit.TextBox() self.bTextBox.Text = omin.ToString() self.mainPanel.Controls.Add(self.bTextBox, 3, 0) self.aButton = Ansys.UI.Toolkit.Button('Update Contour') self.aButton.Click += Ansys.UI.Toolkit.EventDelegate(self.On_Click) self.mainPanel.Controls.Add(self.aButton, 4, 0) def On_Click(self, sender, args): # Here I update the legend res_unit = Tree.FirstActiveObject.Maximum.Unit upperVal = Quantity(float(self.aTextBox.Text), res_unit) lowerVal = Quantity(float(self.bTextBox.Text), res_unit) legendSettings = Ansys.Mechanical.Graphics.Tools.CurrentLegendSettings() noBands = legendSettings.NumberOfBands legendSettings.SetLowerBound(noBands-1,upperVal) legendSettings.SetLowerBound(1,lowerVal) def Window_Close(self, sender, args): Ansys.UI.Toolkit.Application.Quit() class ContourGUI: ex1 = None def __init__(self): self.ex1 = WindowUI() def Run(self): Ansys.UI.Toolkit.Application.Initialize() self.ex1.Show() Ansys.UI.Toolkit.Application.Run() ChangeContours()
