How to merge workflow ?
Adrien Vet
Adrien Vet Member Posts: 10
Name Dropper Photogenic First Comment
edited July 19 in Structures
Hello, I wrote a python result code to plot with dpf the total stiffness energy of named selection with name "R_" + number ("R_1", "R_2", "R_3", etc...).
The user has to select his named selection in the property provider, and the plot appears as a result. My code is :
  define_dpf_workflow(analysis)
  import mech_dpf
  mech_dpf.setExtAPI(ExtAPI)
  # On charge nos résultats
  # On charge notre modème
  model = dpf.Model(dataSource)
  R = this.GetCustomPropertyByPath("Énergie de déformation modale/Sélection").ValueString
R=model.GetNamedSelection(R)
  E = dpf.operators.result.stiffness_matrix_energy()
  E.inputs.data_sources.Connect(dataSource)
  E.inputs.mesh_scoping.Connect(R)
  e = dpf.operators.math.accumulate(E)
  scale = dpf.operators.math.scale()
  scale.inputs.field.Connect(E)
  scale.inputs.ponderation.Connect(0)
  a = e.outputs.getfield().Data[0]
  E_totale = dpf.operators.math.add_constant()
  E_totale.inputs.field.Connect(scale)
  E_totale.inputs.ponderation.Connect(a)
  dpf_workflow = dpf.Workflow()
  dpf_workflow.Add([E, E_totale, e, scale])
  dpf_workflow.SetOutputContour(E_totale)
  dpf_workflow.Record('wf_energy', False)
Then, I want to display all the plots "all the workflow" in on plot.
I have different possible plots and I want the python result to display all the parts in one plot. (with different colors because the stiffness energy is different for each part)
Any help could help,
Thank you
Adrien
  • Chris Harrold
    Chris Harrold Member, Administrator, Employee Posts: 90
    10 Comments First Anniversary First Answer Ansys Employee
    admin
    @Ramdane - can you assist here?
  • Ramdane
    Ramdane Member, Employee Posts: 7
    First Anniversary Ansys Employee Name Dropper First Comment
    assigned it to Varun from the mechanical post team.
    Mike.Thompson Member, Employee Posts: 153
    @Adrien Vet ,
    I think the general idea you need is to manually create a DPF Field object with Elemental scoping. You can then manually set the values of the Field.Data property from a list (DataList) like this:
    DataCollection = System.Collections.Generic.List[System.Double](map(System.Double, DataList))
    You can also use an existing field where you extract the energy of each element, but then simply change the Field.Data values to be whatever you want. This is just to have an operator setup an elemental field rather than do it from scratch.
