hi sir,
I am facing a issue to export my nodal data from transient analysis in MAPDL .
My code
/post26
FILE,'file','rst','.'
/UI,COLL,1
NUMVAR,200
SOLU,191,NCMIT
STORE,MERGE
FILLDATA,191,,,,1,1
REALVAR,191,191
nsel,s,loc,x,0.01495,0.01505
*Get,NoNodes,node,0,count !Get the number of nodes in the selected set
*Dim, MyNodeNoArray,array, NoNodes !Array used to save nodes No.
*SET,SelNode,0
!Counter to save the selected node number
*Do,i,1,NoNodes
*SET,NodeNo,NDNEXT(SelNode) !NDNEXT(N) Next selected node having a node number greater than N.
*SET,MyNodeNoArray(i), NodeNo
*SET,SelNode,NodeNo
/AUTO,1
/REP,FAST
NSOL,i+1,NodeNo,U,X,NodeNo
STORE,MERGE
*Enddo
*CREATE,output,txt
*DIM,_P26_EXPORT,TABLE,401,NoNodes+1
*Do,j,0,NoNodes
VGET,_P26_EXPORT(1,j),j+1
*Enddo
*MWRITE ,_P26_EXPORT,21mm,csv
%G, %G, %G, %G, %G, %G, %G, %G, %G, %G,%G, %G, %G, %G, %G, %G, %G, %G, %G, %G,%G, %G, %G, %G, %G, %G, %G, %G, %G, %G,%G, %G, %G, %G, %G, %G
*END
/INPUT,output,txt
I running a transient analysis and i require time series data for more than 1000 nodes
using mwrite , Im unable to extract more than 41 columns. if i call for more than 41 data it shows format error.
also numvar command takes only 200 variables.
please update my code
