Error Installing/running PyAEDT for AEDT 23R1
Recently I tried to install PyAEDT from the "PyAEDT Installer Python file" from PyAnsys Website as shown in attached Capture1. But I see errors as in Captures 4 when I try to run a/ny code in Jupyter. Also (from Captures 2 & 3), it seems like PyAEDT may not have installed properly for 23R1 on my machine .
Could you see what might be the issue and how to resolve this!
Regards
It turned out that for 23R1 there was a thing that after you install PyAEDT there are certain (two) DLLs that you need to delete otherwise it would give the errors i was seeing and won't be able to run PyAEDT.
Thanks to Ansys support for helping me find it.
@Abhi_SimuTech This seems to be related to permissions for running win32com module.
Could you please try to run python with admin rights? The ultimate solution would be install the pyaedt with admin rights.
Let me know how it goes.
Related issue on stackoverflow: https://stackoverflow.com/questions/46820109/import-error-with-win32com-gen-py
hi @Abhi_SimuTech ,
what files did you need to delete? i am having the same problem.
1 -
@raven0665 said:
hi @Abhi_SimuTech ,what files did you need to delete? i am having the same problem.
I am also having the same problem on 2023R2.1 although it has previously worked this time last year with a previous version
