How to implement Utilization factor procedure in IPython DPF (Mechanical)
bartoszplochocki
bartoszplochocki Member Posts: 1 **
I'm trying to plot utilization factor based on Von Mises stress and arbitrary yield value. My similar script works in CPython, however in Mechanical Python Rsult I'm getting 0s. Von Mises Elemental Mean is plotting correc, but next step is not yielding results
   import mech_dpf
   mech_dpf.setExtAPI(ExtAPI)
#operator init
   seqv = dpf.operators.result.stress_von_mises()
   mean = dpf.operators.averaging.elemental_mean()
   div = dpf.operators.math.component_wise_divide()
#get von mises elementalnodal, step 1
   seqv.inputs.data_sources.Connect(dataSource)
   seqv.inputs.time_scoping.Connect([1.])
   seqv.inputs.requested_location.Connect('ElementalNodal')
#von mises passed to mean operator
   mean.Connect(seqv)
#scalar field with single value for all scoped elements
   element_ids = mean.outputs.getfield().ScopingIds
   yield_f = dpf.FieldsFactory.CreateScalarField(numEntities=len(element_ids), location=dpf.locations.elemental)
   yield_f.Data = [355.]*len(element_ids)
#division operator with von mises and scalar field
   div.inputs.fieldA.Connect(mean.outputs.field.GetData())
   div.inputs.fieldB.Connect(yield_f)
#workflow
   dpf_workflow = dpf.Workflow()
   dpf_workflow.Add(seqv)
   dpf_workflow.Add(mean)
   dpf_workflow.Add(div)
#plot
   dpf_workflow.SetOutputContour(div)
Thank you
Bartosz
  • Rajesh Meena
    @bartoszplochocki
    I am not sure how it worked in CPython but your field for yield should have Scoping support as well.
    Since you know about fieldA, try copying scoping from FieldA (yield_f.Scoping = mean_field.Scoping). I modified your code below.
       import mech_dpf
    #operator init
       seqv.inputs.requested_location.Connect('Elemental')
       mean.Connect(seqv)
       mean_field= mean.outputs.field.GetData()
       div.inputs.fieldA.Connect(mean_field)
    #workflow
    #plot
