Extracting results from a Path in Transient analysis and creating a 3D Surface Plot in PyDPF
George Tzortzopoulos
Member, Employee Posts: 12
The methodology for constructing a conceptual path (not an actual path + result in the tree) with start+end points and # of divisions and mapping a result to these points in PyDPF can be found in the link below:
For creating now the spatiotemporal 3D surface plot of the path result, the Numpy and Matplotlib Python libraries are required. Here is an example of working with Temperature results:
from ansys.dpf.core.plotter import DpfPlotter import numpy as np
from matplotlib import cm """
Load result file and create model database
""" path = "my_Path" ds = dpf.DataSources(path)
model = dpf.Model(ds) mesh = model.metadata.meshed_region """
Select preferable Named Selection
""" get_NSs = model.metadata.available_named_selections my_mesh_scoping = model.metadata.named_selection("my_Named_Selection") """
Scope Named Selection to corresponding Mesh
""" scoping_op = dpf.operators.mesh.from_scoping()
scoping_op.inputs.scoping.connect(my_mesh_scoping)
scoping_op.inputs.mesh.connect(mesh) my_mesh = scoping_op.outputs.mesh() """
Get Temperature results at all time instants
""" get_all_temps = model.results.temperature.on_all_time_freqs
get_fieldContainers_temperature = get_all_temps(mesh_scoping=my_mesh_scoping).eval() """
Create Path Field
""" startCoordinate = [-0.022225, -0.012065, 0.00375918]
endCoordinate = [-0.046355, 0.012065, 0.00375918]
ipoints = 47 dxyz = (np.array(endCoordinate) - np.array(startCoordinate))/(ipoints+1) pathCoordinates = [startCoordinate]
for i in range(1,ipoints+2):
pathCoordinates.append((startCoordinate + i * dxyz).tolist()) field_coord = dpf.fields_factory.create_3d_vector_field(len(pathCoordinates))
field_coord.data = pathCoordinates
field_coord.scoping.ids = list(range(1, len(pathCoordinates) + 1)) """
Map Temperatures to Path coordinates
""" mapping_op = dpf.operators.mapping.on_coordinates(
fields_container=get_fieldContainers_temperature,
coordinates=field_coord,
create_support=True,
mesh=mesh
temp_fields_mapped = mapping_op.outputs.fields_container() """
Plot Temperature w.r.t to Path Distance & Time using Matplotlib - 3D Surface Plot
""" tf = model.metadata.time_freq_support
time = np.array(tf.time_frequencies.data) start = np.array(pathCoordinates[0])
distance = np.zeros(len(pathCoordinates))
for i in range(len(pathCoordinates)):
finish = np.array(pathCoordinates[i])
distance[i] = np.linalg.norm(start-finish) Temps = np.zeros((len(time), len(distance)))
for i in range(Temps.shape[0]):
Temps[i,:] = np.array(temp_fields_mapped[i].data) Distance, Time = np.meshgrid(distance*1000, time) fig, ax = plt.subplots(subplot_kw={"projection": "3d"}) surf = ax.plot_surface(Time, Distance, Temps, cmap=cm.coolwarm, linewidth=0, antialiased=False)
fig.colorbar(surf, shrink=0.5, aspect=5, label="Temperature [degC]")
ax.view_init(elev=30, azim=30, roll=0)
ax.set_xlabel("Time [s]")
ax.set_ylabel("Path Distance [mm]")
ax.set_zlabel("Temperature [degC]")
plt.show()0
