How do I get the geometry unit in Mechanical?
Rajesh Meena
Moderator, Employee Posts: 135
The geometry dimensions will not returned in active unit system. How do I check the unit system for geometry parameters?
The geometry unit will not be in SI Unit always. You can use below script to get geometry Unit. It would be dependent on CAD unit.
I use below script whenever I want to calculate the mesh from geometry dimensions.
GeometryUnit=str(ExtAPI.DataModel.Project.Model.Geometry.LengthUnit) #Unit of geometry UnitDict={'StandardMKS':'m','StandardNMM':'mm','StandardUMKS':'um','StandardBIN':'in','StandardBFT':'ft','StandardCGS':'cm'} LengthUnit=UnitDict[GeometryUnit] #Unit of mesh size1
