How to get stress tensors on edge of a shell in python results, by defining position and layer
Kev
Kev Member Posts: 43
  • Ayush Kumar
    Ayush Kumar Member, Moderator, Employee Posts: 495
    edited July 2023 Answer ✓
    Hi @Kev,
    You need use the operatordpf.operators.utility.change_shell_layers() for specifying the layers.
     0:Top, 1: Bottom, 2: BottomTop, 3:Mid, 4:BottomTopMid
    You can read more about it in the DPF operator help. Below is an example code which works well. You can create custom properties (drop-down) to select the Shell-Layer and the Coordinate System.
    import mech_dpf
    mech_dpf.setExtAPI(ExtAPI)
    sx = dpf.operators.result.stress_X()
    sx.inputs.data_sources.Connect(dataSource)
    ns_op = dpf.operators.scoping.on_named_selection()
    ns_op.inputs.data_sources.Connect(dataSource)
    ns_op.inputs.requested_location.Connect('Nodal')
    ns_op.inputs.named_selection_name.Connect('EDGE')
    sx.inputs.mesh_scoping.Connect(ns_op.outputs.mesh_scoping)
    sx.inputs.bool_rotate_to_global.Connect(False)
    sx_top = dpf.operators.utility.change_shell_layers()
    sx_top.inputs.fields_container.Connect(sx)
    Define Shell layer
    sx_top.inputs.e_shell_layer.Connect(0)
  • Kev
    I would like to create a python result file that mimics a user plot With the populated fields as shown in the figure below:
    So far this is as far as I have gone with the code below (Showing just a section of the code):
    DisplayDict = {}
    DisplayDict[0] = dpf.locations.nodal
    DisplayDict[1] = dpf.locations.elemental
    DisplayDict[2] = dpf.locations.elemental_nodal
    GrphicsTypeDict = {}
    GrphicsTypeDict[1] = dpf.enums.GFXContourType.GeomFaceScoping
    #endregion
    MeshScoping=MeshScopingFromNS(NS)
    global TimeFreqSupport
    TimeFreqSupport=GetResultsTimeData()
    WriteMessage("Setup results operator")
    ResultOp = dpf.operators.result.stress_X () #dpf.operators.result.stress_von_mises()
    ResultOp.inputs.bool_rotate_to_global.Connect(False)
    ResultOp.inputs.mesh_scoping.Connect(MeshScoping)
    TimeScoping=GetTimeScoping(TimeSelectionType, Step, CalcTimeHistory)
    ResultOp.inputs.time_scoping.Connect(TimeScoping)
    ResultOp.inputs.data_sources.Connect(dataSource)
    if Display==0 or Display==1:
    ResultOp.inputs.requested_location.Connect(DisplayDict[Display])
    When I evaluate this pyresult, I get a different stress distribution which tells me some of the properties are not set correctly.
    Would appreciate the help with this greatly :)
    Cheers
  • Kev
    Hi Ayush thanks for the help.
    I did make adjustments to the code as per your instructions however I am still struggling to replicate the results of the user plot.
    I have attached an archived file with my python result file and the user plot file in there. would greatly appreciate it if someone could have a look and tell me what an I missing.
    Here's the result of the user plot:
    And here is what my Python result is producing:
    Here is the updated code just in case. Will appreciate the help :
    #region Get the user property values
    GroupName="Options"
    CS = PropValue(GroupName+"/"+"Coordinate System")
    Position = int(PropValue(GroupName+"/"+"Position"))
    Display = int(PropValue(GroupName+"/"+"Display Option"))
    global DebugMode
    DebugMode = bool(int(PropValue(GroupName+"/"+"Debug Mode")))
    GroupName="Time Points"
    TimeSelectionType = int(PropValue(GroupName+"/"+"Time Selection Type"))
    Step = int(PropValue(GroupName+"/"+"Step"))
    CalcTimeHistory = bool(int(PropValue(GroupName+"/"+"Calculate Time History")))
    NS = PropValue("Scoping/Scoping/Named Selection")
    #endregion
    #region import standard modules
    global dataSource
    DisplayDict = {}
    #endregion
    ResultOp.inputs.bool_rotate_to_global.Connect(False) #setting to solution coordiante system
    sx_top.inputs.fields_container.Connect(ResultOp)
    sx_top.inputs.e_shell_layer.Connect(0)#0:Top, 1: Bottom, 2: BottomTop, 3:Mid, 4:BottomTopMid
    WriteMessage("Get displacement operator for showing warped model")
    u = dpf.operators.result.displacement()
    uMeshScoping=MeshScopingFromNS(NS, requested_location=dpf.locations.nodal)
    u.inputs.mesh_scoping.Connect(uMeshScoping)
    u.inputs.time_scoping.Connect(dpf.TimeFreqScopingFactory.ScopingByLoadSteps([Step]))
    u.inputs.data_sources.Connect(dataSource)
    WriteMessage("region Setup the final workflow")
    dpf_workflow = dpf.Workflow()
    GraphicsType = GetGraphicsType(NS)
    OutputContourObj = sx_top
    if GraphicsType!=None:
    dpf_workflow.SetOutputContour(sx_top, GraphicsType)
    else:
    dpf_workflow.SetOutputContour(sx_top)
    dpf_workflow.SetOutputWarpField(u)
    return
  • Ayush Kumar
    edited July 2023
    @Kev , Looking at line 12 of your code above, I am not sure of the way you are scoping the nodes. I suggest select the edges, create a named selection, convert that into nodes and then use the nodal named selection in the scoping of the DPF code. That should give you the same results.
  • Ayush Kumar
    @Kev, I would recommend you to reach out via the standard Ansys Technical support, as this might involve model debugging and hence not a post for Ansys Developer Forum but a question for standard Ansys Technical Support. There you can even share your model and one of the Ansys Tech Support Engineers will help you debug the issue.
