Referencing scriptable extension using the command
I would like to reference the script extension using the command. Is it possible to add specific extension directory path?
I would like to than load the extension using Extension.LoadExtension…
  • Landon Mitchell Kanner
    ScriptedExtensionLocation = r'C:\Users\lmkanner\Downloads\lin_stress_src\src'
    ExtId = "0A0459A2-03BE-4F49-973C-A5459F65E58B".ToLower()
    CurrentLocations = GetPreferenceValue('ACT_AdditionalExtensionsFolders')
    UpdatedLocations = ScriptedExtensionLocation+';'+CurrentLocations
    SetPreference('ACT_AdditionalExtensionsFolders', UpdatedLocations)
    CleanProject()
    Extensions.LoadExtension(Id=ExtId,Format="Scripted")
    Preference IDs can usually be found here:
    {ANSYS Installation folder}\commonfiles\registry\winx64
    In this example, ACT_AdditionalExtensionsFolders can be found in ACTPrefernces.xml in the above folder location.
