Heat passed through contact surface with the use of PyDPF
Dimosthenis Tsalagradas
Dimosthenis Tsalagradas Member, Employee Posts: 2
How to calculate the heat that has passed through a contact surface with the use of PyDPF?
  • Dimosthenis Tsalagradas
    The script below measures the heat that has passed through the selected contact surface by getting the CONTA174 element heat flow and plots it at a specific time step of the analysis. Also it sums up and prints the total heat that has passed through the preferable contact surface during the whole analysis.
    A prerequisite for the generation of the contact surface named selection is to add the following APDL command under the desired contact:
    my_cont = cid
    And the following command object before solution:
    /PREP7
    ESEL, S, TYPE, , my_cont
    CM, PCB_CONT, ELEM
    ALLSEL
    /SOLU
    The PyDPF script is as follows:
    from ansys.dpf.core.plotter import DpfPlotter
    import numpy as np
    Load result file and create model database
    path = "../../model/file.rth"
    ds = dpf.DataSources(path)
    model = dpf.Model(ds)
    Select preferable Named Selection set in Mechanical
    get_NSs = model.metadata.available_named_selections
    mesh_scoping = model.metadata.named_selection("PCB_CONT_2")
    Scope Named Selection to corresponding Mesh
    scoping_op = dpf.operators.mesh.from_scoping()
    scoping_op.inputs.scoping.connect(mesh_scoping)
    scoping_op.inputs.mesh.connect(mesh)
    my_mesh = scoping_op.outputs.mesh()
    Get Heat Flow results at last time step
    contact_heatFlow_op = dpf.operators.result.nmisc(
        # time_scoping=-1,
        mesh_scoping=mesh_scoping,
        data_sources=ds,
        item_index=98,
    contact_heatFlow_res = contact_heatFlow_op.outputs.fields_container()
    Contour Plot: Heat Flow
    sargs = dict(title="Contact Heat Flow [J]", title_font_size=30, label_font_size=20)
    plot = DpfPlotter()
    plot.add_field(contact_heatFlow_res[0], my_mesh, show_max=True, show_min=True, notebook=False, scalar_bar_args=sargs)
    plot.show_figure(show_axes=True)
    Total Heat Flow through contact(s)
    heat_flow = np.sum(np.array(contact_heatFlow_res[0].data))
    print("Total Heat Flow: ", round(heat_flow,2), " [J]")
