How to calculate contact surface and heat flow with the use of PyDpf
Kleanthis
Member, Employee Posts: 6
The script below captures the contact for each element by getting the CONTAC174 element and calculates its contact surface. Afterwards it calculates the heat flux of each element.
A prerequisite for the generation of the contact surface named selection is to add the following APDL command under the desired contact:
my_cont=cid
And the following command object before solution:
/PREP7 ESEL, S, TYPE, , my_cont CM, PCB_CONT, ELEM ALLSEL /SOLU
The PyDPF script is as follows:
from ansys.dpf import core as dpf from ansys.dpf import core as dpf from ansys.dpf.core.plotter import DpfPlotter import numpy as np """ Load result file and create model database """ ds = dpf.DataSources("file.rth") model = dpf.Model(ds) # %% get_NSs = model.metadata.available_named_selections print(get_NSs) # %% mesh_scoping = model.metadata.named_selection("PCB_CONT_2") print(mesh_scoping) # %% print(get_NSs) mesh_scoping = model.metadata.named_selection("PCB_CONT_2") print(mesh_scoping) # %% contact_status_op = dpf.operators.result.nmisc( # time_scoping=-1, mesh_scoping=mesh_scoping, # fields_container=my_fields_container, # streams_container=my_streams_container, data_sources=ds, # mesh=my_mesh, item_index=41, # num_components=my_num_components, ) print(contact_status_op) # %% contact_status_res = contact_status_op.outputs.fields_container() print(contact_status_res) # %% scoping_op = dpf.operators.mesh.from_scoping() scoping_op.inputs.scoping.connect(mesh_scoping) scoping_op.inputs.mesh.connect(contact_status_res[0].meshed_region) my_mesh = scoping_op.outputs.mesh() print(my_mesh) # %% plot = DpfPlotter() plot.add_field(contact_status_res[0], my_mesh, notebook=False) plot.show_figure(show_axes=True) # %% touch_cond = (contact_status_res[0].data >= 2.) Nelems_touch = sum(touch_cond) print("Number of Touching Elements: ", Nelems_touch) print("Number of Total Elements: ", len(contact_status_res[0].data)) # %% contact_area_op = dpf.operators.result.nmisc( # time_scoping=-1, mesh_scoping=mesh_scoping, # fields_container=my_fields_container, # streams_container=my_streams_container, data_sources=ds, # mesh=my_mesh, item_index=58, # num_components=my_num_components, ) print(contact_area_op) # %% contact_area_res = contact_area_op.outputs.fields_container() print(contact_area_res) # %% print(contact_area_res[0].data) # %% scoping_op = dpf.operators.mesh.from_scoping() scoping_op.inputs.scoping.connect(mesh_scoping) scoping_op.inputs.mesh.connect(contact_area_res[0].meshed_region) my_mesh = scoping_op.outputs.mesh() print(my_mesh) # %% plot = DpfPlotter() plot.add_field(contact_area_res[0], my_mesh, show_max=True, show_min=True, notebook=False) plot.show_figure(show_axes=True) # %% contact_heatFlux_op = dpf.operators.result.smisc( # time_scoping=-1, mesh_scoping=mesh_scoping, # fields_container=my_fields_container, # streams_container=my_streams_container, data_sources=ds, # mesh=my_mesh, item_index=14, # num_components=my_num_components, ) print(contact_heatFlux_op) # %% contact_heatFlux_res = contact_heatFlux_op.outputs.fields_container() print(contact_heatFlux_res) # %% scoping_op = dpf.operators.mesh.from_scoping() scoping_op.inputs.scoping.connect(mesh_scoping) scoping_op.inputs.mesh.connect(contact_heatFlux_res[0].meshed_region) my_mesh = scoping_op.outputs.mesh() print(my_mesh) # %% plot = DpfPlotter() plot.add_field(contact_heatFlux_res[0], my_mesh, show_max=True, show_min=True, notebook=False) plot.show_figure(show_axes=True)
1
