How can I calculate joint forces on MPC184 elements using PyDPF?
Ayush Kumar
Ayush Kumar Member, Moderator, Employee Posts: 367
100 Answers 100 Comments 100 Likes First Anniversary
  • Ayush Kumar
    edited August 17
    You need to know the MPC184 Element ID, that can be found using the User Defined Result in Mechanical "PNUMELEM" and then use the following code.
    rst_path = r"\Path\to\file.rst"
    model = dpf.Model(rst_path)
    ms = dpf.Scoping()
    """ MPC 184 Element ID eg. 3774 """
    ms.ids = [3771] jfx = model.operator("mapdl::smisc")
    jfx.inputs.mesh_scoping.connect(ms)
    """ Use the following indexes in the next line.
    1: Fx, 2: Fy, 3: Fz """ jfx.inputs.item_index.connect(1)
    fx = jfx.outputs.fields_container.get_data()[0].data
