Create coordinate system with vector components
Jimmy He
Member, Employee Posts: 27
If I know the vector components of the principal coordinate axes, how should I go about creating a coordinate system using Mechanical scripting?
Below is a code snippet to achieve this:
`import math ########################################################## # Created by P. Thieffry # Last update: 2021/04/07 def dotProduct(v1,v2): return v2[0]*v1[0]+v2[1]*v1[1]+v2[2]*v1[2] def TransformationMatrix(origCS,targCS): # compute transformation matrix to align origCS to targCS # All coordinates are expressed in the global CS # tMat=[[dotProduct(origCS[0],targCS[0]),dotProduct(origCS[0],targCS[1]),dotProduct(origCS[0],targCS[2])], [dotProduct(origCS[1],targCS[0]),dotProduct(origCS[1],targCS[1]),dotProduct(origCS[1],targCS[2])], [dotProduct(origCS[2],targCS[0]),dotProduct(origCS[2],targCS[1]),dotProduct(origCS[2],targCS[2])]] return tMat ########################################################## ########################################################## # Modified from: https://learnopencv.com/rotation-matrix-to-euler-angles/ def rotationMatrixToEulerAngles_ZYX( R ) : sy = math.sqrt(R[0][0] * R[0][0] + R[1][0] * R[1][0]) singular = sy < 1e-6 factor = 180./math.pi if not singular : x = math.atan2(R[2][1] , R[2][2])*factor y = math.atan2(-R[2][0], sy)*factor z = math.atan2(R[1][0], R[0][0])*factor else : x = math.atan2(-R[1][2], R[1][1])*factor y = math.atan2(-R[2][0], sy)*factor z = 0 return [z, y, x] ########################################################## def norm( v ): return ( v[0]**2 + v[1]**2 + v[2]**2 )**0.5 def unit_vec( v ): n = norm( v ) return [ _/n for _ in v ] def CreateCS( origin , xyz , name , unit='mm' ): # Create coordinate testCS = ExtAPI.DataModel.Project.Model.CoordinateSystems.AddCoordinateSystem() testCS.OriginDefineBy= CoordinateSystemAlignmentType.Fixed testCS.OriginX = Quantity(origin[0],unit) testCS.OriginY = Quantity(origin[1],unit) testCS.OriginZ = Quantity(origin[2],unit) # Get rotations origCS = [[1,0,0],[0,1,0],[0,0,1]] tMat = TransformationMatrix(origCS,xyz) angs = rotationMatrixToEulerAngles_ZYX(tMat) ########################################################## # Created by M.H. Pernelle # Last update: 2021/06 # Perform transformation testCS.PrimaryAxisDefineBy = CoordinateSystemAlignmentType.GlobalX # Rotation Z testCS.RotateZ() testCS.SetTransformationValue(1,angs[0]) # Rotation Y testCS.RotateY() testCS.SetTransformationValue(2,angs[1]) # Rotation X testCS.RotateX() testCS.SetTransformationValue(3,angs[2]) ########################################################## # Set name testCS.Name = name # Example xyz = [[0.5,0.5,-0.70711],[-0.14645,0.85355,0.5],[0.85355,-0.14645,0.5]] CreateCS( [1,2,3] , xyz , 'my_cs' , unit='m' )
@Jimmy He ,
If you have any time/desire I am hoping to expand this solution to have a function that creates a CS with inputs of XYZ origin and a Z vector definition. X and Y can be arbitrary, but the Z direction should be from a unit vector.Thanks for any help with this.
2 -
Please see the updated solution here. The user can specify the unit of the origin XYZ. Angle unit is detected in the code and appropriate conversion is performed.
import math ########################################################## # Created by P. Thieffry # Last update: 2021/04/07 def dotProduct(v1,v2): return v2[0]*v1[0]+v2[1]*v1[1]+v2[2]*v1[2] def TransformationMatrix(origCS,targCS): # compute transformation matrix to align origCS to targCS # All coordinates are expressed in the global CS # tMat=[[dotProduct(origCS[0],targCS[0]),dotProduct(origCS[0],targCS[1]),dotProduct(origCS[0],targCS[2])], [dotProduct(origCS[1],targCS[0]),dotProduct(origCS[1],targCS[1]),dotProduct(origCS[1],targCS[2])], [dotProduct(origCS[2],targCS[0]),dotProduct(origCS[2],targCS[1]),dotProduct(origCS[2],targCS[2])]] return tMat ########################################################## ########################################################## # Modified from: https://learnopencv.com/rotation-matrix-to-euler-angles/ def rotationMatrixToEulerAngles_ZYX( R ) : sy = math.sqrt(R[0][0] * R[0][0] + R[1][0] * R[1][0]) singular = sy < 1e-6 if not singular : x = math.atan2(R[2][1] , R[2][2]) y = math.atan2(-R[2][0], sy) z = math.atan2(R[1][0], R[0][0]) else : x = math.atan2(-R[1][2], R[1][1]) y = math.atan2(-R[2][0], sy) z = 0 return [z, y, x] ########################################################## def norm( v ): return ( v[0]**2 + v[1]**2 + v[2]**2 )**0.5 def unit_vec( v ): n = norm( v ) return [ _/n for _ in v ] def cross(a, b): result = [a[1]*b[2] - a[2]*b[1], a[2]*b[0] - a[0]*b[2], a[0]*b[1] - a[1]*b[0]] return result def CreateCS( origin , z , name , unit='mm' ): angle_unit = DataModel.CurrentUnitFromQuantityName("Angle") convert_factor = Quantity(1,'rad').ConvertUnit( angle_unit ).Value # Create coordinate testCS = ExtAPI.DataModel.Project.Model.CoordinateSystems.AddCoordinateSystem() testCS.OriginDefineBy= CoordinateSystemAlignmentType.Fixed testCS.OriginX = Quantity(origin[0],unit) testCS.OriginY = Quantity(origin[1],unit) testCS.OriginZ = Quantity(origin[2],unit) z_unit = unit_vec(z) x_unit = unit_vec([ z_unit[1] , -z_unit[0] , 0 ]) y_unit = unit_vec(cross(z_unit, x_unit)) xyz = [ x_unit , y_unit , z_unit ] # Get rotations origCS = [[1,0,0],[0,1,0],[0,0,1]] tMat = TransformationMatrix(origCS,xyz) angs = rotationMatrixToEulerAngles_ZYX(tMat) ########################################################## # Created by M.H. Pernelle # Last update: 2021/06 # Perform transformation testCS.PrimaryAxisDefineBy = CoordinateSystemAlignmentType.GlobalX # Rotation Z testCS.RotateZ() testCS.SetTransformationValue(1,angs[0]*convert_factor) # Rotation Y testCS.RotateY() testCS.SetTransformationValue(2,angs[1]*convert_factor) # Rotation X testCS.RotateX() testCS.SetTransformationValue(3,angs[2]*convert_factor) ########################################################## # Set name testCS.Name = name # Example z = [1.,1.,0.] CreateCS( [0,0,0] , z , 'my_cs' , unit='m' )
