I am working on building a script to pull forces from beam connections in a model. In my test model I have 2 shells with holes cut in each and a beam connection between them.
In the UI I can place a 'Beam Probe' and get all the data I need, but I cannot seem to get it through DPF. I get the same error with Output Controls -> Nodal Forces turned on.
The error I keep getting is F:233<-Source operator "mapdl::rst::F" not found. Using ANSYS 2023R2. My code is:
import mech_dpf
model = dpf.Model(analysis.ResultFileName)
mesh = model.Mesh
# Get the beam elements
op_scope = dpf.operators.scoping.on_mesh_property()
op_scope.inputs.requested_location.Connect("element")
op_scope.inputs.property_name.Connect("beam_elements")
op_scope.inputs.mesh.Connect(model.Mesh)
op_scope.outputs.mesh_scoping.GetData()
# DPF Scoping:
# with Elemental location and 2 entities
op_scope_t = dpf.operators.scoping.transpose()
op_scope_t.inputs.mesh_scoping.Connect(op_scope)
op_scope_t.inputs.meshed_region.Connect(mesh)
op_scope_t.outputs.mesh_scoping.GetDataT1()
# DPF Scoping:
# with Nodal location and 4 entities
op_nodal = dpf.operators.result.nodal_force(data_sources=model.DataSources, mesh_scoping=op_scope_t.outputs.mesh_scoping)
op_nodal.outputs.fields_container.GetData()
# Error F:233<-Source operator "mapdl::rst::F" not found
