What are the diffrence in prfar between v21 and v22?
When the "prfar" functionality capability of predicting "SUMC" based directly on the harmonic surface responce from half of a tube surface is compared are there seen a significant diffrence between the outcome from v21R2 and v22R2! (for a flat plate the outcome is found to be the same)
Could you please guide me to where in you release notes I can read about the updates there have been introduced betrween ANSYS v21R2 and v22R2 regarding "prfar"
Best regards Alf
Release notes for v2022R2 can be found here:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/ai_rn/global_releasenotes.htmlHowever, I do not see any mention of the prfar command in the release notes. I suggest you contact our technical support team for additional support:
https://www.ansys.com/it-solutions/contacting-technical-support0
