How do I define a Pull(Extrude) Mesh Edit in Mechanical?
Pernelle Marone-Hitz
Member, Moderator, Employee Posts: 900
Adapt the following code:
mesh = ExtAPI.DataModel.Project.Model.Mesh extrude = mesh.AddPullExtrude() extrude.Location = ExtAPI.SelectionManager.CurrentSelection # this scopes a face that is manually selected in Mechanical. Adapt this to your own needs. For robustness, using a named selection is recommended extrude.Height = Quantity("2[mm]") mesh.GenerateMesh() extrude.Generate()
