DPF Install issue
I used the Ansys Python Manager to download python and relevant libraries.
When I do that and then try to run dpf in with the following command
in Jupyter notebook I get the following error.
AttributeError                            Traceback (most recent call last)
Cell In[1], line 1
----> 1 from ansys.dpf import core as dpf
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\ansys\dpf\core\__init__.py:101
     97 SERVER_CONFIGURATION = None
     99 _server_instances = []
--> 101 settings.set_default_pyvista_config()
    102 settings._forward_to_gate()
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\ansys\dpf\core\settings.py:35, in set_default_pyvista_config()
     32 if module_exists("pyvista"):
     33     import pyvista as pv
---> 35     pv.rcParams["interactive"] = True
     36     pv.rcParams["cmap"] = "jet"
     37     pv.rcParams["font"]["family"] = "courier"
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\pyvista\__init__.py:95, in __getattr__(name)
     93     feature = inspect.getattr_static(sys.modules['pyvista.plotting'], name)
     94 except AttributeError as e:
---> 95     raise AttributeError(f"module 'pyvista' has no attribute '{name}'") from None
     97 return feature
AttributeError: module 'pyvista' has no attribute 'rcParams'`
**Any idea what could be causing this? **
I included a text file with my installed packages for reference.
Here is a list of my installed packages.
Best Answers
  • tdarling
    tdarling Member Posts: 3
    I updated to ansys-dpf-core 0.9.0 and it worked which was surprising since I'm running ANSYS 2023 R2.
  • Paul Profizi
    Paul Profizi Member, Employee Posts: 4
    First Answer Ansys Employee Name Dropper First Comment
    Hi @tdarling,
    The installer gets you the latest version of the PyVista package, package which introduced a breaking change for ansys-dpf-core with its 0.41.0 release.
    See this exact issue on GitHub https://github.com/ansys/pydpf-core/issues/1058.
    This was fixed in the 0.9.0 release of ansys-dpf-core which is why it now works.
    The issue here is that the installer gets you the packages marked as compatible with Ansys 2023R2, along with the latest versions of our dependencies as they are not pinned.
    The PyAnsys packages marked as compatible with Ansys 2023R2 are the latest ones that were released at the time as we do a snapshot of all our packages and make sure they are inter-compatible.
    As for you remark
    we do test and ensure retro-compatibility between ansys-dpf-core releases and several previous releases of ANSYS, which is why ansys-dpf-core 0.9.0 is compatible with ANSYS 2023R2, 2023R1, and 2022R2.
    @Sandeep Medikonda @Ramdane I will look into updating the Ansys Python Installer. Maybe we need to release a patched version of ansys-dpf-core 0.8.2 and pin this one for Ansys 2023R2.
