How can I perform a parametric analysis through PyMechanical?
MSensale
Member, Employee Posts: 4
Here is an example code to perform a parametric analysis through PyMechanical with parameters that are not parametrized by Mechanical itself.
Here is the code :
from ansys.mechanical.core import launch_mechanical from pathlib import Path ############################################################################### # Launch Mechanical # ~~~~~~~~~~~~~~~~~ # Launch a new Mechanical session in batch, setting ``cleanup_on_exit`` to # ``False``. To close this Mechanical session when finished, this example # must call the ``mechanical.exit()`` method. mechanical = launch_mechanical(batch=False, cleanup_on_exit=False) print(mechanical) ############################################################################### # Define parameters # ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ P1 = [0.001, 0.005, 0.01, 0.05, 0.1] # Maximum Time Step P2 = [3, 2.5, 2, 1.5, 1, 0.5, 0.25] # Face Sizing and Face Sizing 2 P3 = ["Linear"] #Element order P4 = ["PurePenalty"] #Contact formulation P5 = ["NodalNormalToTarget", "NodalProjectedNormalFromContact", "NodalDualShapeFunctionProjection"] # Detection Method names = ['Max Time Step', 'Sizing', 'Order', 'Formulation', 'Detection'] parameters = [P1,P2,P3,P4,P5] param = dict(zip(names, parameters)) for key, value in param.items(): length = (len(value)) for j in range(0, length): print(value[j]) ################################################################################### # Open the Mechanical model # ~~~~~~~~~~~~~~~~~~ # Run the Mechanical script to attach the geometry and set up and solve the # analysis. file = r"D:\\Data\\project1\\SYS-99.mechdb" command = f'ExtAPI.DataModel.Project.Open("{file}")' # RUN LINES TO PERFORM PRELIMINARY OPERATIONS # ~~~~~~~~~~~~~~~~~~ mechanical.run_python_script(command) command = """ import json #Scenario 1: Store main Tree Object items MODEL = Model GEOM = MODEL.Geometry COORDINATE_SYSTEMS = Model.CoordinateSystems MESH = Model.Mesh NAMED_SELECTIONS = Model.NamedSelections CONNECTIONS = Model.Connections PARTS = GEOM.GetChildren(DataModelObjectCategory.Part,False) for part in PARTS: bodies = part.GetChildren(DataModelObjectCategory.Body, False) for body in bodies: if body.Name == "Part 1": PART1 = body STAT_STRUC = DataModel.Project.Model.Analyses[0] ANALYSIS_SETTINGS = STAT_STRUC.AnalysisSettings STAT_STRUC_SOLUTION = STAT_STRUC.Solution""" output = mechanical.run_python_script(command) print(output) # CHANGE THE PARAMETER # ~~~~~~~~~~~~~~~~~~ if key == 'Max Time Step': command = """ ANALYSIS_SETTINGS.Activate() ANALYSIS_SETTINGS.CurrentStepNumber=2 ANALYSIS_SETTINGS.MaximumTimeStep=Quantity("{0:.3f} [sec]") """.format(value[j]) if key == 'Sizing': command = """ MESH.Children[1].ElementSize = Quantity({0:.1f}, "m") MESH.Children[2].ElementSize = Quantity({0:.1f}, "m")""".format(value[j]) if key == 'Order': command = """ MESH.ElementOrder = ElementOrder.{0:s}""".format(value[j]) if key == 'Formulation': command = """ CONNECTIONS.Children[0].Children[0].ContactFormulation = ContactFormulation.{0:s} CONNECTIONS.Children[0].Children[1].ContactFormulation = ContactFormulation.{0:s}""".format(value[j]) if key == 'Detection': command = """ CONNECTIONS.Children[0].Children[0].DetectionMethod = ContactDetectionPoint.{0:s} CONNECTIONS.Children[0].Children[1].DetectionMethod = ContactDetectionPoint.{0:s}""".format(value[j]) print(command) output = mechanical.run_python_script(command) print(output) # UPDATE MESH AND SOLVE # ~~~~~~~~~~~~~~~~~~ command = """ # Solve Static Analysis MESH.GenerateMesh() STAT_STRUC = Model.Analyses[0] STAT_STRUC.Solution.Solve(True)""" output = mechanical.run_python_script(command) print(output)
2
