Update the mesh in PyAnsys
Samukham
Samukham Member Posts: 41
I would like to update one mesh with another mesh using a PyMAPDL command. Specifically, I have a .db file that I'll load using the PyMAPDL command mapdl.resume(). After loading it, I save the mesh as a new parameter, let's call it original_mesh. Next, I make some modifications to node locations using the mapdl.n() command. Then, I perform an analysis on the modified mesh. Once the analysis is complete, I need to replace the modified mesh with the original_mesh. One approach to achieve this is by restoring the modified node locations to their original values, But, for that I need to run a mapdl.n() commad in a loop, and it is time consuming as the no. of nodes are very large.
Is there a way to directly replace the modified mesh with the original_mesh without the need for any loops or node-by-node updates?
Example:
mapdl = launch_mapdl()
fname='modalat.db'
mapdl.resume(fname)
original_mesh = mapdl.mesh.grid.copy
mapdl.prep7()
mapdl.n(10,1,2,3)
mapdl.n(11,2,0,0)
mapdl.run('/SOLU')
mapdl.solve()
!Here I need to replace mapdl.mesh with original_mesh
Please suggest how to do the same.
Thanks,
Dr. Samukham
  • James Derrick
    James Derrick Administrator, Employee Posts: 358
    admin
    @Rohith Patchigolla or @M do you have any ideas?
    @Samukham, what do you mean by replace the mesh? When you run an analysis the results file is written and the mesh data is included. There is no tool to rewrite that data with different node locations. We can however still use it in conjunction with that alternate node data via DPF and other means. For that I again need more info about what you mean by “replacing” the mesh and more importantly, the meaningful end goal.
  • Rohith Patchigolla
    @Samukham, could you simply resume the db again to get the previous mesh. db file should still have the old mesh as you have not saved it.
    fname='modalat.db'
    mapdl.resume(fname)
    mapdl.prep7()
    mapdl.n(10,1,2,3)
    mapdl.n(11,2,0,0)
    mapdl.run('/SOLU')
    mapdl.solve()
    mapdl.resume(fname)
  • Samukham
    edited September 2023
    Hi @Mike.Thompson,
    By replacing mesh I mean, bringing back all the nodes to their original position. To be specific, first I resume a .db file, modify the few node positions, and then solve the modified model. Once the solution procedure is complete I need to bring back all the modified nodes to their original position. I have the original nodal positions in the .db file. I'm looking for a direct command that'll bring back all the modified nodes to their original positions all at once.
    Thanks,
  • German Martinez
    German Martinez Member, Employee, GitHub-issue-creator Posts: 13
    10 Comments Second Anniversary Name Dropper Ansys Employee
    @Samukham If you don't mind to lose the results (because you have post processed everything), then just use mapdl.resume.
    If you want to keep the results, you can rename your job first, then do the changes, solve, save, resume to the original database, and repeat.
    Draft of code
    Not tested!
    # create base model
    mapdl.save("base_model.cdb")
    mapdl.jobname = "model_with_changes_1"
    # do changes to get model 1
    mapdl.n("...")
    mapdl.d("...")
    # etc...
    # Solve
    mapdl.solution()
    mapdl.solve()
    # post processing
    mapdl.post_processing.plot_nodal_displacements("X")
    # etc
    # Resuming to base database
    mapdl.save()
    mapdl.resume("base_model.cdb")
  • Samukham
    Thank you @German Martinez, I'll try the recommended method.
