Are stresses extracted from DPF global or local to the element orientation
Mike.Thompson
Member, Employee Posts: 94
When using DPF to extract stresses are the values returned in the global system, or the local element system?
The stress operators have an input "bool_rotate_to_global" that is often default = True. This will be in the global system by default, but setting this to False will keep in the element orientation.
import mech_dpf
import Ans.DataProcessing as dpfop = dpf.operators.result.stress() # operator instantiation
op.inputs.bool_rotate_to_global.Connect(False) # optional
`0
