How can I using scripting get displacements as function of time at certain areas ?
Erik Kostson
Member, Employee Posts: 165
We have a named selection in a mechanical transient (structural) system and we want to write all of the displacement for every time step to a text file for further post processing. How can we do that using mechanical scripting?
Below is a sample script that does that (gets the nodes of the 1st named selection):
model=ExtAPI.DataModel.Project.Model # refer to Model reader = model.Analyses[0].GetResultsData() # get results data of first analysis in the tree analysis = model.Analyses[0] ns=model.NamedSelections.Children nodeids=ns[0].Location.Ids # change nodal named selection / picks the 1st one DataSets=reader.ListTimeFreq f1=open("D:\\test.txt","w") #open file in user directory for node in nodeids: for si in range(0,len(DataSets),1): reader.CurrentTimeFreq = DataSets[si] myDeformation = reader.GetResult("U") deformynode = myDeformation.GetNodeValues(node)[1] # y -disp[1] nx=ExtAPI.DataModel.MeshDataByName("Global").NodeById(node).X f1.write(str(float(DataSets[si]))+ " ," + str(node)+ " , " + str(nx)+ " , " +str(deformynode) +"\n") f1.close()
