Tabular load implemented from Python scripting
Luiza
Luiza Member Posts: 7
edited October 11 in General Language Questions
Hello everyone
I am working in Ansys Workbench 2022R2 in a coupled field module. I am adding loads from scripting. With a single value works easily, but I want to use tabular data for the load. Can i read tabular data for a load from scripting?
Can i set the step end time in analysis settings with input from csv?
  • Jaaroon
    Jaaroon Member Posts: 6
    edited October 11
    I assume you are trying to define a tabular load in Mechanical.
    If you provide load and related timestep values as lists this should not be a problem. It could be that you first have to define the number of timesteps in the analysis.
    Maybe my example for a pressure load below can help you:
    get analysis object
    Analysis = ExtAPI.DataModel.AnalysisByName("AnalysisName")
    define time steps for simulation
    Analysis.AnalysisSettings.NumberOfSteps = len(tsteps)-1
    for i,t in enumerate(tsteps,1):
    Analysis.AnalysisSettings.CurrentStepNumber = i
    Analysis.AnalysisSettings.StepEndTime = Quantity("{} [sec]".format(t))
    generate lists of tabular values
    time_vals = [Quantity("{} [sec]".format(t)) for t in tsteps]
    pressure_vals = [Quantity("{} [Pa]".format(p)) for p in pressure loads]
    define new pressure load for selection
    PressureLoad = Analysis.AddPressure()
    PressureLoad.Location = selection
    PressureLoad.Magnitude.Inputs[0].DiscreteValues = time_vals
    PressureLoad.Magnitude.Output.DiscreteValues = pressure_vals
    Mike.Thompson Member, Employee Posts: 158
    @Jaaroon @Luiza ,
    you can also make a 'Quantity' entity like this: Quantity(12,'N')
    you simply give it a number as arg1 and unit as string as arg2.
