How to create a named selection of nodes which have equivalent stress above a certain limit?
Rohith Patchigolla
Rohith Patchigolla Member, Moderator, Employee Posts: 253
I have an equivalent stress result in Mechanical. I want to create a nodal named selection which has nodes corresponding to equivalent stress above a certain value
  • Rohith Patchigolla
    edited October 2023 Answer ✓
    Here is a simple script (tested in 2021R2). Please try pasting this script in Mechanical Scripting Console after solving the model. This should create a new Nodal named selection with the corresponding nodes.
    #Inputs
    #Stress Limit in MPa
    strLimitMPa = 10
    #Use the name of the Equivalent Stress object in the tree (try to have a unique name for the result objects)
    stress_Object_Name = "Equivalent Stress 1"
    #Remainig Code
    strLimit = strLimitMPa*1e6
    eqvStr = DataModel.GetObjectsByName(stress_Object_Name)[0]
    plt = eqvStr.PlotData
    scopedNodes = plt["Node"]
    scopedResults = plt["Values"]
    # Get indices of elements in scopedResults  that are greater than certain stress value
    indices = [i for i, value in enumerate(scopedResults) if value > strLimit]
    # Filter scopedNodes list based on the indices
    filtered_scopedNodes = [scopedNodes[i] for i in indices]
    nodeSel = ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.MeshNodes)
    nodeSel.Ids = filtered_scopedNodes
    NsObj = DataModel.GetObjectsByType(DataModelObjectCategory.NamedSelections)
    if len(NsObj) == 0:
        newNodalNS = Model.AddNamedSelection()
    else:
        newNodalNS = Model.NamedSelections.AddNamedSelection()
    newNodalNS.Location = nodeSel
    newNodalNS.Name = "NodesAboveLimit_" + str(strLimitMPa) + "_MPa_" + eqvStr.Name
    Tree.Refresh()
