UDFs for modelling heat transfer in a porous medium
sutherlandshire
Member Posts: 1 **
Hello, I am unsure if this is the place to ask this, however I am really struggling to create UDFs to fit a numerical model which must be applied as UDFs in ANSYS Fluent to model a phase change material in a porous medium. I have attached the mathematical model I am trying to follow as well as my current code. I am specifically stuck on adding the energy source term, however I am also facing difficulty in adding an interfacial area. I believe my source terms in FxFy SxSy are correct however I am not definite on this. Any help would be greatly appreciated.
#include "udf.h" #define Tsolidus 300.0 #define Tliquidus 304.0 #define L_f 250 //Latent heat of fusion #define UDM_RHO_F_PREV 0 // UDM index for storing previous rho_f #define UDM_LAMBDA_PREV 1 // UDM index for storing previous lambda DEFINE_EXECUTE_ON_LOADING(init_values, udf_name) { Thread *t; cell_t c; Domain *d = Get_Domain(1); // Get domain using Fluent API, assuming single-phase flow /* Loop over all cells to initialize UDM values */ thread_loop_c(t, d) { begin_c_loop_all(c, t) { C_UDMI(c,t,UDM_RHO_F_PREV) = 1000.0; //initializing previous rho_f C_UDMI(c,t,UDM_LAMBDA_PREV) = 0.0; //initializing previous lambda } end_c_loop_all(c, t) } } DEFINE_SOURCE(energy_sourceN, c, t, dS, eqn) { real lambda, lambda_prev, V[ND_ND], rho_f, Sl, d_lambda_dt, grad_lambda_dot_V, T, rho_f_prev; T = C_T(c, t); rho_f = C_R(c, t); C_CENTROID(V, c, t); rho_f_prev = C_UDMI(c, t, UDM_RHO_F_PREV); // Fetch the previous value of rho_f from UDM lambda_prev = C_UDMI(c, t, UDM_LAMBDA_PREV); // Fetch the previous value of lambda from UDM // Calculate lambda if (T < Tsolidus) lambda = 0.0; else if (T > Tliquidus) lambda = 1.0; else lambda = (T - Tsolidus) / (Tliquidus - Tsolidus); // Calculate d(lambda*rho_f*L_f)/dt d_lambda_dt = ((rho_f * lambda * L_f * 0.85) - (rho_f_prev * lambda_prev * L_f * 0.85)) / CURRENT_TIMESTEP; // The gradient calculation requires more attention. Below is just a placeholder, and you need to implement the correct gradient calculation. grad_lambda_dot_V = (C_R_G(c,t)[0] * V[0] + C_R_G(c,t)[1] * V[1]) * lambda * L_f; Sl = d_lambda_dt + grad_lambda_dot_V; dS[eqn] = 0; // Adjust the source term linearization if necessary // Store the current time step values of rho_f and lambda to UDM C_UDMI(c, t, UDM_RHO_F_PREV) = rho_f; C_UDMI(c, t, UDM_LAMBDA_PREV) = lambda; return Sl; } DEFINE_SOURCE(F_xmomentum, c, t, dS, eqn) { real mu_f, rho_f, K, C, magnitude_V, force; real velocity[ND_ND]; velocity[0] = C_U(c,t); // u-component velocity[1] = C_V(c,t); // v-component /* Fetching effective viscosity and density from Fluent */ mu_f = C_MU_EFF(c, t); // Dynamic Viscosity of fluid rho_f = C_R(c,t); // Density of fluid K = 1.452827637854882e-04; // Define or fetch the value of K C = 0.058424315707417; // Define or fetch the value of C magnitude_V = sqrt(velocity[0]*velocity[0] + velocity[1]*velocity[1]); force = (mu_f/K + rho_f*C*magnitude_V/sqrt(K)) * (velocity[0]); dS[eqn] = 0; // source term linearization, adjust if necessary return force; } DEFINE_SOURCE(F_ymomentum, c, t, dS, eqn) { real mu_f, rho_f, K, C, magnitude_V, force; real velocity[ND_ND]; velocity[0] = C_U(c,t); // u-component velocity[1] = C_V(c,t); // v-component /* Fetching effective viscosity and density from Fluent */ mu_f = C_MU_EFF(c, t); // Dynamic Viscosity of fluid rho_f = C_R(c,t); // Density of fluid K = 1.452827637854882e-04; // Define or fetch the value of K C = 0.058424315707417; // Define or fetch the value of C magnitude_V = sqrt(velocity[0]*velocity[0] + velocity[1]*velocity[1]); force = (mu_f/K + rho_f*C*magnitude_V/sqrt(K)) * (velocity[1]); dS[eqn] = 0; // source term linearization, adjust if necessary return force; } DEFINE_SOURCE(S_xmomentum,c,t,dS,eqn) { real velocity[ND_ND], Am, lambda, T, source; velocity[0] = C_U(c,t); // u-component velocity[1] = C_V(c,t); // v-component Am = 10000; // Mushy Zone Constant T = C_T(c, t); if (T < Tsolidus) lambda = 0.0; else if (T > Tliquidus) lambda = 1.0; else lambda = (T - Tsolidus) / (Tliquidus - Tsolidus); source = (Am * ((1.0 - lambda)*(1.0 - lambda)) /(lambda*lambda*lambda+0.001))*velocity[0] ; return source; } DEFINE_SOURCE(S_ymomentum,c,t,dS,eqn) { real velocity[ND_ND], Am, lambda, T, source; velocity[0] = C_U(c,t); // u-component velocity[1] = C_V(c,t); // v-component Am = 10000; // Mushy Zone Constant T = C_T(c, t); if (T < Tsolidus) lambda = 0.0; else if (T > Tliquidus) lambda = 1.0; else lambda = (T - Tsolidus) / (Tliquidus - Tsolidus); source = (Am * ((1.0 - lambda)*(1.0 - lambda)) /(lambda*lambda*lambda+0.001))*velocity[1] ; return source; } DEFINE_SOURCE(h_sf,c,t,dS,eqn) { real dl, epsilon, mu, rho, nu, pr, rho_pcm, u, v, mu_pcm, k_pcm, Re_d, h_sf; dl = 0.0194; //Diameter Matlab epsilon = 0.85; //Porosity Matlab mu = C_MU_L(c,t); // Laminar viscosity rho = C_R(c,t); // Density nu = mu/rho; // Kinematic Viscosity pr = nu/rng_alpha(1.,mu,mu); // Prandtl Number rho_pcm = C_R(c,t); u = C_U(c,t); v = C_V(c,t); mu_pcm = C_MU_L(c,t); k_pcm = C_K_L(c,t); Re_d = (rho_pcm * sqrt(u*u + v*v) *dl) / (epsilon * mu_pcm); if (Re_d > 0 && Re_d <= 40) h_sf = (0.76 * pow(Re_d, 0.4) * pow(pr, 0.37) * k_pcm)/dl; else if (Re_d > 40 && Re_d <= 1000) h_sf = (0.52 * pow(Re_d, 0.5) * pow(pr, 0.37) * k_pcm)/dl; else if (Re_d > 1000 && Re_d <= 20000) h_sf = (0.26 * pow(Re_d, 0.6) * pow(pr, 0.37) * k_pcm)/dl; else Error("Re_d value out of range!\n"); exit(1); return h_sf; }
@Ryan OConnor - minus the script formatting issues here, can you provide some assistance perhaps?
