How do I extract Mode Shapes with Result file on remote machine using PyDPF?
Ayush Kumar
Ayush Kumar Member, Moderator, Employee Posts: 367
100 Answers 100 Comments 100 Likes First Anniversary
edited October 17 in Structures
How do I extract Mode Shapes with Result file on remote machine using PyDPF~~~~?
  • Ayush Kumar
    edited October 17
    Replace the remote DPF server's IP and port in line 13 and RST file path on the remote machine in line 14.
    import time
    from ansys.dpf.core.plotter import DpfPlotter
    from ansys.dpf.core import animation
    # Retrieve mode shapes
    t1 = time.time()
    server = dpf.connect_to_server(ip="<IP>", port=<port>)
    rst_path = r"\Path\to\file.rst"
    # Load the result file as a model
    model = dpf.Model(rst_path)
    n_modes = model.metadata.time_freq_support.n_sets
    freqs = model.metadata.time_freq_support.time_frequencies.data
    t2 = time.time()
    print("Time taken to calculate freqs - %s seconds" % round((t2 - t1), 2))
    time_scoping = dpf.Scoping()
    time_scoping.ids = range(1, n_modes + 1)
    print(model.metadata.meshed_region)
    # Skin Mesh
    skin_mesh = dpf.operators.mesh.skin(mesh=model.metadata.meshed_region)
    skin_op = skin_mesh.outputs.mesh.get_data()
    print(skin_op)
    t11 = time.time()
    # Extract the displacement results which define mode shapes
    disp = model.results.displacement(mesh_scoping=skin_mesh.outputs.nodes_mesh_scoping,
                                      time_scoping=time_scoping).outputs.fields_container.get_data()
    t21 = time.time()
    print("Time taken to extract displacements - %s seconds" % round((t21 - t11), 2))
    # Plot mode shapes
    # Get the frequency scoping (available frequency IDs for disp)
    freq_scoping = disp.get_time_scoping()
    # Get the frequency support (all available frequencies in the model)
    freq_support = disp.time_freq_support
    # Get the unit from the time_freq_support
    unit = freq_support.time_frequencies.unit
    # For each ID in the scoping
    for index, freq_set in enumerate(freq_scoping):
        t10 = time.time()
        # Get the associated frequency in the time_freq_support
        freq = freq_support.get_frequency(cumulative_index=freq_set - 1)
        # Get the associated mode shape as a displacement field
        disp_mode = disp.get_field_by_time_complex_ids(freq_set, 0)
        data = disp_mode.data
        t20 = time.time()
        print("Time taken to extract Mode-%s is %s seconds" % (freq_set, round((t20 - t10), 2)))
