Hello! I am currently working on an extension that uses a custom object in the Tree. The object is not a load object, but it does create apdl commands before the solve.
For some context the tree looks like this, where I create a custom folder, and then a custom object.
The custom Tree object then writes apdl commands using "getcommands" in the xml file.
Per the XML documentation the object will send the object, solver data, and stream so the apdl commands can be issued.
The issue I am having is that I need to determine the analysis that the object is writing the commands to. Normally for a load object you can access this by just using object.Analysis, but the general object does not have this as it is not located under an analysis in the tree.
Does anyone know of a way to determine what analysis the apdl commands are being written to for a general object? I checked the solver data and stream and I don't see a way to tie the commands back to the analysis that the commands are writing to.
