Is there an example of how to use ansysli_util.exe?
Landon Mitchell Kanner
Member, Employee, GitHub-issue-creator Posts: 353
I want to get information about Ansys license usage, license availability, and/or the license server. How can I utilize the Ansys license utility (ansysli_util.exe )?
import shlex import subprocess import os def getCapabilityAvailability(Capability): if 'ANSYSLIC_DIR' in os.environ: #Keep the unclosed quote lminstallfolder = '"'+os.environ['ANSYSLIC_DIR']+'\\winx64\\' licfile = '"'+os.environ['ANSYSLIC_DIR']+'\\license_files\\ansyslmd.lic"' else: #Keep the unclosed quote lminstallfolder = '"C:\\Program Files\\ANSYS Inc\\Shared Files\\Licensing\\winx64\\' licfile = '"C:\\Program Files\\ANSYS Inc\\Shared Files\\Licensing\\license_files\\ansyslmd.lic"' #All license features with given capability if os.path.isfile(os.path.normcase(lminstallfolder.replace('"',''))+'ansysli_util.exe'): if os.path.isfile(os.path.normcase(licfile.replace('"',''))): runstr = lminstallfolder+'ansysli_util.exe"'+' -capcount '+Capability args = shlex.split(runstr) p = subprocess.Popen(args,stdout=subprocess.PIPE, stderr=subprocess.PIPE) value, error = p.communicate() value_string=value.decode("utf-8") if value_string[0] != 'N' and value_string[0] != 'E': availableLicenses = int(value_string) if availableLicenses != 0 : availableLicenses = int(value_string) #print(str(availableLicenses)+' licenses to run capability '+Capability+' available') else: #print('All of '+capability+' are in use.') availableLicenses = 0 else: #print('No capability to run '+Capability+' available.') availableLicenses = 0 else: #print('Can\'t find license file') availableLicenses = 0 else: #print('Can\'t find license utility') availableLicenses = 0 return availableLicenses
1
