This is currently a limitation. If any user tries to use Python Result with an unconverged analysis, an error message will pop up and the Python Result will have the red lightning not plotting any result.
A workaround to overcome this limitation is to create a new dummy analysis where no load is introduced, just an empty APDL snippet command. On that dummy analysis, a Python Result is introduced which points to the unconverged rst file.
