Is there any automatic way to imprint washers/bolt heads on a face in Discovery?
Javier Vique
Javier Vique Member, Employee Posts: 90
For instance, let's assume that we've got a wind blade bearing and the idea is to automatically make an imprint of the bolts holes by an edge offset. That offset is given by a ratio of the hole radius. Image below gives an overview of the final target:
  • Javier Vique
    Below a script developed by @Pierre Thieffry to make that imprint on a selection of faces.
    import math
    offset_value=1.1 # Size for edge offset (radius*offset_value)
    max_radius=60 # in mm, will avoid offsets for any circular edge with higher radius
    # For face selection
    AllEdges=[]
    CircularEdges=[]
    EdgeFaces={}
    EdgeRadius={}
    # Get face selection
    selected_faces=Selection.GetActive().GetItems[IDesignFace]()
    # Loop over faces to find circular edges
    if len(selected_faces)!=0:
        for face in selected_faces:
            for edge in face.Edges:
                try:     # Radius will exist only for circular edges
                    radius = MeasureHelper.ArcRadius(EdgeSelection.Create(edge))*1e3
                    if radius<=max_radius:
                        AllEdges.append(edge)
                        EdgeFaces[edge]=face
                except:
                    radius = 0
    else:
        pass
    # Now loop over circular edges
    if len(AllEdges)>0:
        for i in range(len(AllEdges)):
            edge = AllEdges[i]
            try:
                current_face=EdgeFaces[edge]
                face_sel=FaceSelection.Create(current_face)
                edge_selection=EdgeSelection.Create(edge)
                # Compute Offset
                offset = float(offset_value)*radius
                # Create imprint
                direction= MoveImprintEdges.GetImprintDirection(edge_selection,face_sel, False)
                options = MoveImprintEdgeOptions()
                result = MoveImprintEdges.Execute(edge_selection, direction, MM(-offset), options, None)
                # Look at newly created faces to identify which face should be imprinted (when multiple circular edges are on the same face)
                for check_face in result.CreatedFaces:
                    # Face we look for does not contain current edge
                    if edge not in check_face.Edges:
                        new_base_face=check_face
                # As face change after imprint, need to update association between edges and faces
                for edge, face in EdgeFaces.items():
                    if face==current_face:
                        EdgeFaces[edge]=new_base_face
                i = i + 1
            except:
                print('Issue with Imprints - check for possible overlaps')
    This is a great example. I have a few suggestions to make the code more robust if anybody wants to utilize this script at a large scale.
    -> You can determine if an edge is a circle or not with: str(E.Shape.Geometry.GetType()).endswith('Circle'). This would be faster than a try/except most likely if you have lots of non-circle edges.
    -> You can use the built in functions for unit conversions like "MM", "IN" instead of the factors like 1E3
    -> It would be better to group all the imprints that are along the same face into a single imprint operation. Currently the script does each one-by-one, but I think you can imprint multiple edges. Create a block that first identifies the imprints, then group them by face, and do all the edges for that face in a single imprint. This is only for speed with larger models.
