How can we Export and save stress components (x,y,z,xy,xz,yz) to a file?
There are many ways of doing this (e.g., APDL, DPF, Mech scripting, etc.).
One way of many possible is shown here. The mechanical script below, creates these results and saves them both in separate files, and in one single file.
solution = ExtAPI.DataModel.Project.Model.Analyses[0].Solution normal_stressx = solution.AddNormalStress() normal_stressx.NormalOrientation = NormalOrientationType.XAxis normal_stressy = solution.AddNormalStress() normal_stressy.NormalOrientation = NormalOrientationType.YAxis normal_stressz = solution.AddNormalStress() normal_stressz.NormalOrientation = NormalOrientationType.ZAxis shear_stressxy = solution.AddShearStress() shear_stressxy.ShearOrientation=ShearOrientationType.XYPlane shear_stressxz = solution.AddShearStress() shear_stressxz.ShearOrientation=ShearOrientationType.XZPlane shear_stressyz = solution.AddShearStress() shear_stressyz.ShearOrientation=ShearOrientationType.YZPlane solution.EvaluateAllResults() ##separatefiles normal_stressx.ExportToTextFile("D:\mysx.txt") normal_stressy.ExportToTextFile("D:\mysy.txt") normal_stressz.ExportToTextFile("D:\mysz.txt") shear_stressxy.ExportToTextFile("D:\mysxy.txt") shear_stressxz.ExportToTextFile("D:\mysxz.txt") shear_stressyz.ExportToTextFile("D:\mysyz.txt") mysx=normal_stressx.PlotData ##one file plotDatasx= normal_stressx.PlotData.Values[2] plotDatasy= normal_stressy.PlotData.Values[2] plotDatasz= normal_stressz.PlotData.Values[2] plotDatasxy= shear_stressxy.PlotData.Values[2] plotDatasyz= shear_stressyz.PlotData.Values[2] plotDatasxz= shear_stressxz.PlotData.Values[2] nodes= normal_stressx.PlotData.Values[1]# list of node ids fpath = "D:/" fname = "mystresses.txt" f = open(fpath+fname,"w") for ii in range(0,len(nodes)): #print(node) f.write(str(nodes[ii]) +","+ str(plotDatasx[ii]) + "," + str(plotDatasy[ii]) + "," + str(plotDatasz[ii]) + ", " + str(plotDatasxy[ii])+ ", " + str(plotDatasyz[ii])+ ", " + str(plotDatasxz[ii]) +"\n") f.close()
