Is it possible to retrieve information on the parameters defined in the Parameter Set of a WB project schematic?
This script will work from the WB project schematic.
parameter_list = Parameters.GetAllParameters() # retrieve all parameters input_parameter_list = [item for item in parameter_list if item.Usage =='Input'] # work only with input parameters for index,value in enumerate(input_parameter_list): try: print(input_parameter_list[index].Name) print(input_parameter_list[index].DisplayText) print(input_parameter_list[index].Expression) print(input_parameter_list[index].Value.Value) print(input_parameter_list[index].Value.Unit) except: print(input_parameter_list[index].Name) print(input_parameter_list[index].DisplayText) print(input_parameter_list[index].Expression) print(input_parameter_list[index].Value) print('NA')
@Pernelle Marone-Hitz Hi, I'm a newbie to WB scripting. I want to write a simple conditional algorithm based on an output parameter from FLUENT:
The code must show a message based on the value of this single parameter. At first, I've written a simple code like:
for parameter in Parameters.GetAllParameters(): print parameter.DisplayText if parameter.DisplayText == 'flow-time-op': flowtime= parameter
Is this correct?
Also, I have no idea where the result of the "print" command goes inside the WB.
Afterward, I want to show a message box based on the value. I've written this code to this end:
import clr clr.AddReference('System.Windows.Forms') from System.Windows.Forms import Application, Form, Label form = Form(Text="End of Simulation") label = Label(Text="End.") label2 = Label(Text="Not Ended.") if (flowtime>40.0): form.Controls.Add(label) else: form.Controls.Add(label2) Form.ShowDialog(form)
But, when I run this code, it always considers the value of this parameter equal to zero. ( the "else" condition will be shown). I have no idea what the problem is.
Any help would be greatly appreciated.
