How to extract directional acceleration results on a node in ANSYS Motion?
Rohith Patchigolla
Member, Moderator, Employee Posts: 251
Tested in 2023R2. Thanks @Vishnu for the script.
import mech_dpf import Ans.DataProcessing as dpf import os node = 1 analysis = ExtAPI.DataModel.Project.Model.GetChildren(DataModelObjectCategory.Analysis,True) motion_an = filter(lambda x: x.SolverName == 'ANSYSMotion@ANSYSMotion', analysis)[0] work_dir = motion_an.WorkingDir filePath = os.path.join(work_dir,'file.dfr') dataSource = dpf.DataSources(filePath) #Time list timelist = dpf.operators.metadata.time_freq_provider(data_sources=dataSource).outputs.gettime_freq_support().TimeFreqs.Data #Scoping my_scoping = dpf.Scoping(location="Nodal",ids=[node]) #Extract result result_operator = dpf.operators.result.acceleration_X(time_scoping=timelist,data_sources=dataSource,mesh_scoping=my_scoping) result_field_container = result_operator.outputs.fields_container.GetData() for timeid,time in enumerate(timelist): result_field = result_field_container.GetFieldByTimeId(timeid+1) print "Time-->",time,"result-->",list(result_field.Data)
