mapping.on_coordinates operator on tetrahedrons mesh
I have a question regarding the "mapping.on_coordinates" operator. To test my code I use a simple ANSYS model consisting of a beam, meshed with volume elements, fixed on one side and loaded with a lateral force on the other side.
My aim is to determine the stresses along the outside-surface node normals. I have the following piece of code to read in the model and plot the mesh.
and to determine the mapped stresses on the normals:
When I use a hexahedron mesh (sweep mesh) in the ANSYS model, the mapping routine works fine, and I can extract the mapped normal stresses for each node:
However when I re-mesh the ANSYS model with tetrahedron elements:
the same script fails:
I played around with the "use_quadratic_elements" option in the operator but did not find a solution for this behaviour. Any help is appreciated.
With kind regards,
Egbert
@Ramdane - can you assist here?
Hi @Egbert ,
it is my pleasure to assist you.I tried the code shown above for some tetrahedral mesh examples, with success.
In order to reproduce your issue, could you send us the .rst files?Thank you.
P.S. I used the following example:
analysis = examples.download_piston_rod()
model = dpf.Model(analysis)0
