Is there a Python client library for interacting with Minerva?
Landon Mitchell Kanner
Member, Employee, GitHub-issue-creator Posts: 353
I would like to automate some tasks in Minerva using Python scripting. Is this possible?
Once you install the Minerva Transfer Client on your machine (in Minerva click on your initials in the upper-right corner > Tools > Application Launcher), you will have access to the Minerva SDK, which can be accessed in Python as follows:
MinervaPath = r'C:\Program Files\Ansys Inc\Application Launcher\TransferClient' import sys import clr if not MinervaPath in sys.path: sys.path.append(MinervaPath) clr.AddReference("Ansys.Minerva.Sdk") import Ansys.Minerva.Sdk as minerva
Here is sample code to connect to instance of Minerva:
connection = minerva.HttpConnection("https://cdcwisdom1.win.ansys.com/AnsysMinerva") connection.LoginAsync(minerva.BrowserLogin())
How to connect with username and password:
try: creds = minerva.ExplicitCredentials("db_name","login_name",minerva.SecureToken("password")[0]) #IPython? except: creds = minerva.ExplicitCredentials("db_name","login_name",minerva.SecureToken("password")) #CPython? connection.Login(creds)
