Is it possible to consider temperature dependent strength data for safety factor calculation?
Is it possible to consider temperature dependent strength data for safety factor calculation within the stress tool?
It is possible via a Python Result object inside Mechanical. The following script calculates the safety factor considering temperature dependent limit stresses:
def post_started(sender, analysis):# Do not edit this line define_dpf_workflow(analysis) def LinearInterpolation(x,x1,y1,x2,y2): # Simple linear interpolation # Returns -1 if x is outside of [x1,x2] if x<x1 or x>x2: return -1 # out of range if y1==y2: return y1 else: a=(y2-y1)/(x2-x1) b=y1-a*x1 return a*x+b def GetLimitStress(temperature,stress_data): # Find limit stress value for a given temperature # This is done by simple linear interpolation between two # points of a limit stress/temperature curve # Find closest temperature in stress_data num_points=len(stress_data)/2 for i in range(num_points): temp=stress_data[2*i] if temp>temperature: index=i break # Get temperature/limit stress points between which to interpolat if index!=num_points: x2=stress_data[index*2] x1=stress_data[(index-1)*2] y2=stress_data[index*2+1] y1=stress_data[(index-1)*2+1] else: return -2 # temperature value is out of bounds return LinearInterpolation(temperature,x1,y1,x2,y2) # return limit stress def GetLimitStressField(stress,temperatures,stress_data): # From a field of stresses and temperatures, find limit stress # at each node. Stress_data defines the limit stress/temperature curve import mech_dpf import Ans.DataProcessing as dpf stress_nodes=stress.outputs.getfields_container()[0].ScopingIds limit_field=dpf.FieldsFactory.CreateScalarField(1,'Nodal') local_temp=temperatures.outputs.getfields_container()[0] for nid in stress_nodes: temp=local_temp.GetEntityDataById(nid)[0] limit_field.Add(nid,[float(GetLimitStress(temp,stress_data))]) return limit_field def define_dpf_workflow(analysis): import mech_dpf import Ans.DataProcessing as dpf # Define limit stress data as list in form of [temp1,limit_stress1,temp2,limit_stress2,...]) limit_stress_data=[-100.,200.,0.,220.,50.,210.,100,200.,1000.,150.] my_data_sources = dpf.DataSources(analysis.ResultFileName) my_time_scoping = dpf.Scoping() my_time_scoping.Ids = [1] # the first set # Retrieve structural temperature at nodes temperature=dpf.operators.result.structural_temperature(requested_location='Nodal') temperature.inputs.data_sources.Connect(my_data_sources) temperature.inputs.time_scoping.Connect(my_time_scoping) # Retrieve Mises stress at nodes s_eqv_op = dpf.operators.result.stress_von_mises() s_eqv_op.inputs.requested_location.Connect('Nodal') s_eqv_op.inputs.data_sources.Connect(my_data_sources) s_eqv_op.inputs.time_scoping.Connect(my_time_scoping) # Retrieve limit_stress for each node based on Mises and temperature limit_stress=GetLimitStressField(s_eqv_op,temperature,limit_stress_data) # Divide limit stress by Mises stress limit_factor=dpf.operators.math.component_wise_divide() limit_factor.inputs.fieldA.Connect(limit_stress) limit_factor.inputs.fieldB.Connect(s_eqv_op) dpf_workflow = dpf.Workflow() dpf_workflow.Add(limit_factor) dpf_workflow.SetOutputContour(limit_factor) dpf_workflow.Record('wf_id', True) this.WorkflowId = dpf_workflow.GetRecordedId()
1 -
Only for clarification and full context, I wanted to point out that mechanical has this general capability via a stress tool post processing object that will plot factors of safety that are temperature dependent based on material property.
This forum is for scripted solutions, so obviously the solution is on point, and it is a good starting point for implementing more complex or specific processing routines, then what is offered in a native solution.
My understanding is that Mechanical's stress tool will indeed take into account temperature-dependent stress (as we can define E = f(T)),
but natively it is not possible to define that the Tensile Yield Stress is temperature-dependent:
which is what the code from @Patrick Herberich does.0 -
Piggybacking on this solution. I've slightly modified the code so that instead of having the Yield Strenght vs Temp values hard-coded, they are read from a comma delimited csv file placed in the user_files directory of the project.
Code is:
def post_started(sender, analysis):# Do not edit this line define_dpf_workflow(analysis) def user_files_directory(): user_files = '' if ExtAPI.Context == 'Project': user_files = GetUserFilesDirectory() elif ExtAPI.Context == 'Mechanical': import wbjn user_files = wbjn.ExecuteCommand(ExtAPI, "returnValue(GetUserFilesDirectory())") return user_files def LinearInterpolation(x,x1,y1,x2,y2): # Simple linear interpolation # Returns -1 if x is outside of [x1,x2] if x<x1 or x>x2: return -1 # out of range if y1==y2: return y1 else: a=(y2-y1)/(x2-x1) b=y1-a*x1 return a*x+b def GetLimitStress(temperature,stress_data): # Find limit stress value for a given temperature # This is done by simple linear interpolation between two # points of a limit stress/temperature curve # Find closest temperature in stress_data num_points=len(stress_data)/2 for i in range(num_points): temp=stress_data[2*i] if temp>temperature: index=i break # Get temperature/limit stress points between which to interpolat if index!=num_points: x2=stress_data[index*2] x1=stress_data[(index-1)*2] y2=stress_data[index*2+1] y1=stress_data[(index-1)*2+1] else: return -2 # temperature value is out of bounds return LinearInterpolation(temperature,x1,y1,x2,y2) # return limit stress def GetLimitStressField(stress,temperatures,stress_data): # From a field of stresses and temperatures, find limit stress # at each node. Stress_data defines the limit stress/temperature curve import mech_dpf import Ans.DataProcessing as dpf stress_nodes=stress.outputs.getfields_container()[0].ScopingIds limit_field=dpf.FieldsFactory.CreateScalarField(1,'Nodal') local_temp=temperatures.outputs.getfields_container()[0] for nid in stress_nodes: temp=local_temp.GetEntityDataById(nid)[0] limit_field.Add(nid,[float(GetLimitStress(temp,stress_data))]) return limit_field def get_stress_data(): import csv import os limit_stress_data = [] user_dir = user_files_directory() if os.path.exists(os.path.join(user_dir, 'TemperatureDependentYieldStrength.csv')): with open(os.path.join(user_dir, 'TemperatureDependentYieldStrength.csv')) as csv_file: csv_reader = csv.reader(csv_file, delimiter=',') line_count = 0 for row in csv_reader: if line_count == 0: line_count += 1 else: limit_stress_data.append(float(row[0])) limit_stress_data.append(float(row[1])) line_count += 1 else: msg = Ansys.Mechanical.Application.Message('Temperature Dependent Yield Strenght file does not exist', MessageSeverityType.Error) ExtAPI.Application.Messages.Add(msg) return limit_stress_data def define_dpf_workflow(analysis): import mech_dpf import Ans.DataProcessing as dpf # Define limit stress data as list in form of [temp1,limit_stress1,temp2,limit_stress2,...]) limit_stress_data = get_stress_data() my_data_sources = dpf.DataSources(analysis.ResultFileName) my_time_scoping = dpf.Scoping() my_time_scoping.Ids = [1] # the first set # Retrieve structural temperature at nodes temperature=dpf.operators.result.structural_temperature(requested_location='Nodal') temperature.inputs.data_sources.Connect(my_data_sources) temperature.inputs.time_scoping.Connect(my_time_scoping) # Retrieve Mises stress at nodes s_eqv_op = dpf.operators.result.stress_von_mises() s_eqv_op.inputs.requested_location.Connect('Nodal') s_eqv_op.inputs.data_sources.Connect(my_data_sources) s_eqv_op.inputs.time_scoping.Connect(my_time_scoping) # Retrieve limit_stress for each node based on Mises and temperature limit_stress=GetLimitStressField(s_eqv_op,temperature,limit_stress_data) # Divide limit stress by Mises stress limit_factor=dpf.operators.math.component_wise_divide() limit_factor.inputs.fieldA.Connect(limit_stress) limit_factor.inputs.fieldB.Connect(s_eqv_op) dpf_workflow = dpf.Workflow() dpf_workflow.Add(limit_factor) dpf_workflow.SetOutputContour(limit_factor) dpf_workflow.Record('wf_id', True) this.WorkflowId = dpf_workflow.GetRecordedId()
I am planning to run this code for multiple materials. How can I proceed?
You'll have to identify which body uses which material and restrict the scoping to the node Ids of each body.
Hi @Abath , FYI this is an example I created for multiple bodies and multiple materials:
def post_started(sender, analysis):# Do not edit this line define_dpf_workflow(analysis) def define_dpf_workflow(analysis): ###################################################################### # Usually no need to change this part # Import libraries import mech_dpf import Ans.DataProcessing as dpf import math mech_dpf.setExtAPI(ExtAPI) my_data_sources = dpf.DataSources(analysis.ResultFileName) # Read mesh in results file mesh_op = dpf.operators.mesh.mesh_provider() # operator instanciation mesh_op.inputs.data_sources.Connect(my_data_sources) mesh = mesh_op.outputs.mesh.GetData() ###################################################################### # import materials module import materials # Credit: https://stackoverflow.com/questions/7343697/how-to-implement-linear-interpolation from bisect import bisect_right class Interpolate: def __init__(self, x_list, y_list): if any(y - x <= 0 for x, y in zip(x_list, x_list[1:])): raise ValueError("x_list must be in strictly ascending order!") self.x_list = x_list self.y_list = y_list intervals = zip(x_list, x_list[1:], y_list, y_list[1:]) self.slopes = [(y2 - y1) / (x2 - x1) for x1, x2, y1, y2 in intervals] def __call__(self, x): if self.x_list[0] >= x: return self.y_list[0] elif x >= self.x_list[-1]: return self.y_list[-1] i = bisect_right(self.x_list, x) - 1 return self.y_list[i] + self.slopes[i] * (x - self.x_list[i]) # Prepare all interpolation objects inpt_objs = {} for mat in ExtAPI.DataModel.Project.Model.Materials.Children: # get engineering data material properties for this material matED = mat.GetEngineeringDataMaterial() props = materials.GetMaterialPropertyByName(matED,"Isotropic Hardening") Temp = props['Temperature'][1:] YS = props['Yield Strength'][1:] # Unit at index 0 inpt_objs[ mat.Name ] = Interpolate( Temp , YS ) # Getting mesh info meshData = DataModel.AnalysisList[0].MeshData # reference meshData #print( len(meshData.Elements) ) #print( len(meshData.Nodes) ) mats , nodes = [] , [] for p in DataModel.GetObjectsByType(Ansys.ACT.Automation.Mechanical.Body): bid = p.GetGeoBody().Id mat = p.Material bodyMesh = meshData.MeshRegionById(bid) # get mesh data nodes += list( bodyMesh.NodeIds ) mats += [mat] * bodyMesh.NodeCount node2mat = dict( zip( nodes , mats )) ############################################################################ # Get fields from DPF # vm stress nodal vm = dpf.operators.result.stress_von_mises() vm.inputs.requested_location.Connect('Nodal') vm.inputs.data_sources.Connect(my_data_sources) nIds = vm.outputs.fields_container.GetData()[0].ScopingIds vm = vm.outputs.fields_container.GetData()[0].Data T = dpf.operators.result.structural_temperature() T.inputs.requested_location.Connect('Nodal') T.inputs.data_sources.Connect(my_data_sources) temp = T.outputs.fields_container.GetData()[0].Data # Create a blank field and assign values my_field = dpf.FieldsFactory.CreateScalarField(numEntities=0, location='Nodal') my_field.MeshedRegionSupport = mesh # Calculate field value for i , s , t in zip( nIds , vm , temp ): my_mat = node2mat[i] my_ys = inpt_objs[ my_mat ]( t ) / 1e6 # Convert to MPa, hard coded for demo fos = my_ys / ( s + 1e-6 ) # Insert field value my_field.Add(i,[ fos ]) my_field.ScopingIds = nIds ###################################################################### # Usually no need to change this part # Forward field to an operator to plot it forward = dpf.operators.utility.forward_field() forward.inputs.field.Connect(my_field) dpf_workflow = dpf.Workflow() dpf_workflow.Add(forward) dpf_workflow.SetOutputContour(forward,dpf.enums.GFXContourType.FENodalScoping) dpf_workflow.Record('wf_id', False) this.WorkflowId = dpf_workflow.GetRecordedId() ######################################################################
Just to also hit on this topic one more time and offer an alternate data input area for temperature dependent data. You can make a custom material model with custom user defined model coefficients that are based on temperature.
You can then use the 'materials' module (mechanical scripting) to access the data in this custom model and get temp-dependent data for yield (or anything else you would like).import materials B = ExtAPI.SelectionManager.CurrentSelection.Entities[0] MatDict = materials.GetMaterialAsDictionary(B.Material) UserPropName = 'SomeFatigue' UserModelCoefName = "MyYield" Unit = MatDict[UserPropName][UserModelCoefName][0] Values = MatDict[UserPropName][UserModelCoefName][1] print Unit print Values TempUnit = MatDict[UserPropName]['Temperature'][0] TempValues = MatDict[UserPropName]['Temperature'][1] print TempUnit print TempValues > Pa [50.0, 150.0] K [293.15, 343.15]
1
