How to fill the worksheet for Fatigue Combination?
Hi, I am writing a script for Fatigue combination with inputs from three Random Vibration analysis. I am trying to add Environment Name and Fatigue tool in Fatigue Combination worksheet. Scripts can add load case (row in WorkSheet), But don't see any script option to add data to load cases. Any scripting help is welcome.
Hi Syed,
This can be accomplished with the following script:
tool = DataModel.GetObjectsByName('Fatigue Combination')[0] my_analysis = DataModel.AnalysisList[0] my_fatigue_tool = DataModel.GetObjectsByName('Fatigue Tool')[0] # Get internal object io = tool.InternalObject # Add load case io.AddLoadCase() # Set analysis ID io.EnvironmentId[0]=my_analysis.Id # Set fatigue tool ID io.ToolId[0]=my_fatigue_tool.ObjectId # Set scale factor io.ScaleFactor[0]=1. # Refresh ExtAPI.DataModel.Tree.Refresh()
Note that this solution relies on undocumented commands, which are outside of any Quality Assurance (QA) programs and may not be forward compatible.
@sachinverghese and @Pierre Thieffry , please consider adding a supported method for this.
Same would be good to have for the solution combination tool (say AddLoadCase() or the property NumLoadCombos that are also currently Internal objects).
