Minimum result over frequency and Sweeping Phase in a Harmonic Analysis
Stelios
Member, Employee Posts: 10
How can you extract the minimum principal stress over all frequencies and sweeping phase with amplitude set to false?
import System.Collections.Generic as Collections def post_started(sender, analysis):# Do not edit this line define_dpf_workflow(analysis) # Uncomment this function to enable retrieving results from the table/chart # def table_retrieve_result(value):# Do not edit this line # import mech_dpf # import Ans.DataProcessing as dpf # wf = dpf.Workflow(this.WorkflowId) # wf.Connect('contour_selector', value) # this.Evaluate() #Creating Funcion to multiply data with (-1) def mult_by_neg_1(field): field_data = list(field.Data) return Collections.List[float]([field_data[i]*(-1) for i in range(len(field_data))]) def define_dpf_workflow(analysis): import mech_dpf import Ans.DataProcessing as dpf mech_dpf.setExtAPI(ExtAPI) ds = dpf.DataSources(analysis.ResultFileName) #Retrieving Frequencies op = dpf.operators.metadata.time_freq_provider() op.inputs.data_sources.Connect(ds) my_time_freq_support = op.outputs.time_freq_support.GetData() freq_list = list(my_time_freq_support.TimeFreqs.Data) #Retrieving the minimum principal stress op = dpf.operators.result.stress_principal_3() op.inputs.time_scoping.Connect(freq_list) op.inputs.data_sources.Connect(ds) my_fields_container = op.outputs.fields_container.GetData() my_fc = dpf.FieldsContainer() my_fc.Labels = ["time"] #Running through the results to find min values for j in range(0, 2*len(freq_list), 2): my_fields_container[j].Data = mult_by_neg_1(my_fields_container[j]) my_fields_container[j+1].Data = mult_by_neg_1(my_fields_container[j+1]) op = dpf.operators.min_max.max_over_phase() op.inputs.real_field.Connect(my_fields_container[j]) op.inputs.imaginary_field.Connect(my_fields_container[j+1]) op.inputs.abs_value.Connect(False) # op.inputs.phase_increment.Connect(my_phase_increment) my_field = op.outputs.field.GetData() my_field.Data = mult_by_neg_1(my_field) my_fc.Add(my_field, {"time": j//2+1}) op = dpf.operators.min_max.min_max_by_entity() # operator instantiation op.inputs.fields_container.Connect(my_fc) my_field_min = op.outputs.field_min.GetData() my_field_max = op.outputs.field_max.GetData() op = dpf.operators.utility.forward() # operator instantiation op.inputs.any.Connect(my_field_min) # my_any = op.outputs.any.GetData() dpf_workflow = dpf.Workflow() dpf_workflow.Add(op) # dpf_workflow.Add(nrm) # dpf_workflow.SetInputName(u, 0, 'time') # dpf_workflow.Connect('time', timeScop) dpf_workflow.SetOutputContour(op) dpf_workflow.Record('wf_id', False) this.WorkflowId = dpf_workflow.GetRecordedId()
